Civic LX 93 a/t check engine light takes 20s to turn off
Old Oct 6, 2016 | 04:51 PM
ElMaq's Avatar
Default Civic LX 93 a/t check engine light takes 20s to turn off
Hi guys
I changed my ECU recently and when the car stays 2/3 days without engine turned on, check engine light stays on for 20 / 30 seconds. After I listen fuel pump prime, the light turns off and engine can work.
Old Oct 6, 2016 | 06:59 PM
Former User's Avatar
Default Re: Civic LX 93 a/t check engine light takes 20s to turn off
If you know the main relay is good (ECU pin A7 ground test), then the ECU is almost surely bad.
Old Oct 6, 2016 | 07:15 PM
ElMaq's Avatar
How can I test it?
Old Oct 6, 2016 | 07:20 PM
Check whether the fuel pump always runs during this^ test?
Old Oct 6, 2016 | 07:32 PM
ElMaq's Avatar
I'll test and post here. After the first start, fuel pump starts normal (2 seconds)
Old Oct 7, 2016 | 12:27 PM
ElMaq's Avatar
Sorry, I tried but I don't know how to do the A7 test
Old Oct 8, 2016 | 03:09 PM
ElMaq's Avatar
Civic now stopped and won't start.
Hi, I did the A7 test.
Disconnected A plug
Inserted a jumper wire on A7 plug
Ground this wire on metal under dashboard
Fuel pump didnt prime
Tested main relay wire
Jump wire pin 5 to 7. Fuel pump run
Jump wire pin 1 to 7. Fuel pump run
Jump wire pin 5 and 1 to 7. Fuel pump run and this mode I tried to start engine but it crank and dont start.
Old Oct 8, 2016 | 03:13 PM
Have you resoldered the main relay and also cleaned and tightened the G101 ground connection on the thermostat housing?
Main Relay Fix, Troubleshooting (Honda, Acura) and how to solder
https://youtu.be/qMpgmzGhJeE
Old Oct 8, 2016 | 03:19 PM
ElMaq's Avatar
Thank you RonJ.
I have 2 main relay: old mitsuba and a brand new. Mitsuba I redid resoldering and the brand new the points is all ok. I checked this G101 gnd yesterday and it seems ok. Now my civic is on the sidewalk and dont wanna go to the garage :-(
Old Oct 8, 2016 | 03:22 PM
Do you have a multimeter? It's likely a simple problem, like a bad wire.
Old Oct 8, 2016 | 03:27 PM
ElMaq's Avatar
yes I have multimeter
Old Oct 8, 2016 | 03:29 PM
Good. What is the color of the wire at pin A7 in ECU connector A?
Old Oct 8, 2016 | 03:31 PM
ElMaq's Avatar
A7: green/yellow
Old Oct 8, 2016 | 03:32 PM
Great.
Unplug ECU connector A.
Turn key to ON(II).
Measure voltage to body ground at pin A7.
Post the reading.
Old Oct 8, 2016 | 03:54 PM
ElMaq's Avatar
(-) 00.0
Zero
Old Oct 8, 2016 | 04:00 PM
The wire at A7 runs to pin 8 (Grn/Yel wire) of the main relay.
With the key in ON(II), what voltage do you measure when back probing the Grn/Yel wire at pin 8? The main relay must remain plugged in for this test.
Old Oct 8, 2016 | 04:11 PM
ElMaq's Avatar
(-) 00.0
Zero
Old Oct 8, 2016 | 04:13 PM
Turn key OFF.
Check for continuity to body ground at pins A23 and A24 (black wires) in the ECU connector.
Old Oct 8, 2016 | 04:23 PM
ElMaq's Avatar
Turn key OFF.
Multimeter result: 1 (A23 and A24)
Old Oct 8, 2016 | 04:25 PM
1 Ohm or infinite resistance? What does the meter read if you touch the two probes together?
Old Oct 8, 2016 | 04:30 PM
ElMaq's Avatar
Result: 000
Old Oct 8, 2016 | 04:32 PM
When you untouch the probes, what does the meter read?
Old Oct 8, 2016 | 04:35 PM
ElMaq's Avatar
1 (or I) stay on left side of the LCD.
Like when done on A23 and A24
Old Oct 8, 2016 | 04:42 PM
You found the problem.
The black wires must be grounded at G101 on the thermostat housing. The black wires merge and run as one black wire to a 14P connector on the left side of the engine bay and a 20P connector on the left shock tower. Maybe one of the connectors is not fully seated.
Old Oct 8, 2016 | 05:12 PM
ElMaq's Avatar
The black wires must be grounded at G101 on the thermostat housing. The black wires merge and run as one black wire to a 14P connector on the left side of the engine bay and a 20P connector on the left shock tower. Maybe the connector is not fully seated.
G101 gnd cleaned and tightened.
Connectors seated
