Rich Idle... AFR 11.1
Old Oct 4, 2016 | 08:34 PM
Jimmy Chavez's Avatar
Default Rich Idle... AFR 11.1
vez , 10-05-2016 12:17 AM
Ok guys!! Here we go. I have a 1994 Honda Del sol SiR (b16a3) and it's been turbo for the pass 2 years... Its been tune on hondata s300 v1.. and never had issues with it...I drive this car everyday!!! But a few weeks ago it's been idling pretty rich ... It stays at 11.1 AFR.. Keep in mind my engine coolant Temp is @ 185F and my vacuum pressure is at 20-21 inches...I thought my o2 wideband sensor was bad so I change It (AEM wideban) and no change.. At normal Cruise speed my AFR is at 14.3-14.8 and at WOT is at 11.7-12.1... Please help..
1000cc ID's injectors
340 aeromotive fuel pump
aeromotive fuel regulator
edlebrook manifold
3 inch down pipe and full exhaust
Aeromotive fuel rail
4 bar hondata MAP
tune on 91 octane
stock internals
Old Oct 10, 2016 | 04:43 PM
Berto24's Avatar
Default Re: Rich Idle... AFR 11.1
Check the fuel press, have you changed anything in the tune? Are you idling at the same vacuum hg?
Old Oct 17, 2016 | 04:02 PM
[QUOTE=Berto24;51079689]Check the fuel press, have you changed anything in the tune? Are you idling at the same vacuum hg?[/QUOTE
i replace the fuel management just incase. But no change. I haven't touch my tune.. my vacuum is still same for the pass 2 years.. I might have a bad injector
Old Oct 17, 2016 | 08:54 PM
boosted94gsr's Avatar
Pull your plugs and check them. If one of your injectors is dumping too much fuel it will show on the plug.
Jimmy Chavez
Engine Management and Tuning
Oct 18, 2016 08:53 AM
HyperFlow
May 15, 2010 06:28 PM
Dawson21
Jun 14, 2004 09:34 AM
LOwrestling2001
Aug 16, 2002 11:21 PM
