rpm random drop
Old Oct 4, 2016 | 04:53 PM
battmancjz's Avatar
Default rpm random drop
my integra rpm has been acting really ackward, the other day i was on 3rd gear and rpm was around 4k when all of a sudden my rpm drop to under 1k and jump right back onto 4k, it was really quick and yes when that happen my car did feel like i downshifted and slowed down drastically. it did it only that time that day in a 2 hour drive. fast forward two days later and it did it again and when i got to the stop light the car shut off, it didnt have any hesitation when it shut off i literally got to the light, the car went to reagular iddle position and after like 1 min it shut off has if i would turn the key off.
I turned it back on and went on my way, i ddid take about 3 tries and i did smell fuel when i was trying to start it. now if i turn my car on and rev it while just still, if i go over 4k , the rpm will have random drops too.
any ideas guys what map be causing this? i change the spark plugs, map sensor and main relay but it has not stop the symptoms.
Old Oct 5, 2016 | 01:19 PM
fcm's Avatar
fcm
Old Fart
Default Re: rpm random drop
Check ICM, [igniter] it will effect spark and your tachometer. 94
Old Oct 8, 2016 | 05:48 AM
trm4life's Avatar
It's likely the distributor or the coil inside
Old Oct 10, 2016 | 10:00 PM
Green9088's Avatar
Sounds like distributor
aznromeo4u
Apr 21, 2024 12:03 PM
AMCooper
Jun 19, 2021 01:16 PM
949
Oct 14, 2009 05:19 PM
d_EG COUPE
Honda S2000
21
Oct 31, 2008 04:17 AM
trooper0641
24
Jan 13, 2006 02:34 PM
