98 Prelude OBD2 to OBD1 Question!
Hi,
I am almost done with auto to manual transmission swap. I have a jdm p13 ecu OBD1, can i just buy OBD2 to OBD1 conversion harness and use the p13 ecu?
Engine is H22A
Engine is H22A
check before swapping , before buying the conversion it comes in both the obd's .. obd2a and obd2b see your connectors and it'll work perfectly all right with your p13 ecu no issues .
Thanks for the reply. It is OBD2A. My buddy told my that I need a chipped ecu because obd2 injectors different that obd1 injectors and the obd1 p13 won't run the car properly
