Lighting HID/Xenon kits, Retrofits and Associated Topics
New ballast, headlight now blue
Old Sep 29, 2016 | 07:36 AM
shewantsthed16's Avatar
Default New ballast, headlight now blue
Hey guys,
Last week my passenger side ballast pooped the bed. Since it had no markings on it, I just ordered a 35W set of ballasts to be safe rather than sorry. After installing it, my passenger side light is now blue in the high and low beam (both lights were bright white before). I feel like the obvious answer is that I should have ordered a 55W ballast instead but I wanted to double check here. Is it possible for a lower watt ballast to change the color?
Thanks
Old Sep 29, 2016 | 01:25 PM
street_ride14's Avatar
Default Re: New ballast, headlight now blue
50w ballast would typically drop color temp by 1000K due to increased intensity, so yes that may be what you are experiencing once going back to 35w ballast, in your case you have gained approx. 1000K temp from prior setup, so makes sense that your color looks more blue
Old Oct 11, 2016 | 12:21 PM
LowTEC SaiMike's Avatar
I usually replace in pairs to avoid this color issues
b16bri
Paint and Body
Jun 7, 2011 07:18 AM
khronicboy420
Jan 3, 2011 03:16 AM
addiction2bass
Jun 16, 2006 04:27 PM
eL
Honda Civic (2006 - 2015)
Apr 26, 2006 10:07 AM
Pikachu
Mar 17, 2006 08:14 PM
