AC works, Condenser fan doesn't.
Old Sep 28, 2016 | 04:20 PM
FlewByU352's Avatar
Default AC works, Condenser fan doesn't.
I've ran into a bit of a problem that at first was intermittent and is now constant. My condenser fan no longer turns on and for some reason won't power even with other fans. Swapped out relays and tested power at the fuse box, everything is perfect. Tested for power at the condenser fan connector and it has over 12 volts when you hit the AC button. However with a fan plugged in I get nothing. I considered the possibility of a bad ground, even though I checked the voltage using the ground terminal in the connector, so I cleaned a different spot and moved the ground. Still nothing. Both fans I have tested with cabled directly to the battery and they power up.
Old Sep 28, 2016 | 04:37 PM
Former User's Avatar
Default Re: AC works, Condenser fan doesn't.
Maybe poor contact of pins in the connectors. Or damaged pins.
Old Sep 28, 2016 | 04:51 PM
FlewByU352's Avatar
i considered that so I even went as far as making a jumper harness with blade terminals to push into the other connector and checking voltage at the other end.
Old Sep 28, 2016 | 04:53 PM
Add car information your first post.
Unplug the fan connector.
On the fan side of the connector, do you measure continuity to body ground on the ground pin using a multimeter.
On the wire harness side,what voltage do you read at the power wire pin?
Old Sep 28, 2016 | 05:41 PM
mk378's Avatar
Put the minus end of your meter on the battery (-) and leave it there. Unplug the compressor so you don't get an overpressure due to fan not running. Plug everything else in. Turn on the A/C. Measure voltage at both leads of the fan to battery - (ground). One should be 12 volts and one zero. If both are zero there is a problem in the power source side of the circuit. If both are 12 volts there is a problem in the ground side of the circuit. You can then measure other places along the line to see where the voltage is being lost.
john79
May 25, 2018 08:32 AM
ek9_B18C
Oct 6, 2012 02:59 PM
Swell_Ryder
Aug 14, 2011 02:45 AM
Panda hatch
Jun 15, 2006 09:43 PM
