Hulog Plugged, car dies & Solid CEL (cant use Hulog and Ostrich at the same time)
Old Sep 28, 2016 | 07:52 AM
Zeratul's Avatar
Icon5 Hulog Plugged, car dies & Solid CEL (cant use Hulog and Ostrich at the same time)
Hello everyone, anybody here got an issue like this before?
i did everything Blundell told me, but still no luck. now my ostrich doesn't seems to work properly too.
1. plug the Ostrich to ECU
2. verify connection between ostrich and ECU
3. Remove checksum, Added RTP
4. uncheck unwanted sensors in options
5. toggle RTP
6. hit write, verify and real time update
7. turn key KOEO
8. fuel pump primes, main relay clicks and CEL shuts off after 2-3seconds
9. start the car
10. plug the Hulog to laptop / ECU (car suddenly die)
11. CEL stays solid
12. start the car again (car ran like crap)
13. verify connection between Hulog and ECU
14. hit live tuning
15. after 2-3 seconds i get a notice "Bad Response, check settings"
16. turn off the car, close crome
17. unplugged the ostrich, put Old Chip back
18. turn key KOEO
19. fuel pump primes, main relay clicks and CEL shuts off after 2-3seconds
20. start the car
21. hit live tuning and it works perfectly
it seems that i cant use Hulog and Ostrich at the same time. can somebody help me?
Old Sep 28, 2016 | 01:52 PM
theYBLEGAL's Avatar
Loved
Default Re: Hulog Plugged, car dies & Solid CEL (cant use Hulog and Ostrich at the same time)
Was this ECU ever working properly before?
Check your soldering work, also verify your hulog pinouts are correct
Old Sep 28, 2016 | 03:31 PM
Zeratul's Avatar
solder is fine, ECU working properly. Hulog pinouts are correct. I did a livetuning before but without the ostrich so hulog pins are correct.
everytime i connect Hulog to ECU or laptop i get a solid CEL.
(e.g.) I use orstrich on my ECU, CEL shuts off, start the car. Hulog connected to ECU, i plug it on my laptop then car dies CEL appears.
I disconnect Ostrich, put my old chip back CEL shuts off, start the car. Hulog connected to ECU, plug it on laptop. car ran fine no CEL, livetuning works perfectly.
everytime the USB cable touch the port CEL cliks and appears. it seems that i cant use them at the same time.
94civiccpe
Jul 18, 2013 07:48 PM
hotinteggy
Oct 22, 2007 04:44 PM
blackeg
Apr 3, 2007 07:07 AM
trooper0641
Feb 1, 2006 10:22 PM
