JDM ZC tranny/ USDM Si Final gear ???
Old Nov 8, 2002 | 11:02 AM
EF7's Avatar
EF7
Default JDM ZC tranny/ USDM Si Final gear ???
Anyone knows what parts are required to install a USDM Si final drive on a JDM ZC tranny??? thanks.
Old Nov 8, 2002 | 12:43 PM
jlicrx's Avatar
Default Re: JDM ZC tranny/ USDM Si Final gear ??? (EF7)
if you have one of each tranny, then you have everything you need - you need to replace the zc countershaft with the si (using the zc gears) and switch the ring gears (bolts are left hand thread) - don't try to put the entire si differential into the zc case - it doesn't fit - if you have been running the zc tranny then you have the correct axles - if you have been running the si tranny then you will need different axles.
Old Nov 8, 2002 | 02:03 PM
nikitad's Avatar
Default Re: JDM ZC tranny/ USDM Si Final gear ??? (jlicrx)
If you don't wanna be getting an SI tranny just to get the parts from it, I have an SI final drive (countershaft+ring gear) for sale.
Also curious:
don't try to put the entire si differential into the zc case - it doesn't fit.
Why? I don't have a first hand experience in this yet, but why would it not fit?
From what I know SI and ZC use the same size differential bearings (unless it's an 88 SI).
Have you tried to do it yourself? Asking to know for sure for future.
Old Nov 8, 2002 | 04:54 PM
Hondasaurs's Avatar
Default Re: JDM ZC tranny/ USDM Si Final gear ??? (nikitad)
I use the SI Tranny.....
33 in 1st
57 in 2nd
87 in 3rd
?? in 4th
?? in 5th
NightHawkC5
May 2, 2006 04:28 PM
Ahknodd
Apr 2, 2006 01:20 PM
DOHClessEF-9
Feb 16, 2005 07:56 PM
davens
Aug 24, 2003 03:08 AM
dRuNk-dRiVer
Feb 17, 2003 07:50 PM
