No start fuel pump not engaging wiring help
Okay I bought my accord from someone that had a local high school swap the motors .
ended up getting it started and such .
went out one day and it wouldn't crank at all , all the lights come on and all other accs work but the car wouldn't even engage to start . I couldn't figure out what was wrong with it . Starter good . Below is what I've done to get it to crank over . Help out be appreciative .
Re ran :
bulk/white wire(s) ignition to fuse box/starter to fuse box by bypassing the fuse box . Run the wire from starter and wire from ignition and wires them together .
the car is cranking now but won't starter . I'm not getting fuel . The fuel pumps not engaging . But in postiive it's good . I'm pretty sure something up in my fuse box . Can I bypass the fuse box or interal wiring and rewire the fuel pump ? Or anyone give any other suggestion .
Re ran :
naterpatater77
Feb 7, 2007 12:37 PM
