Will a 92 integra dash fit in the 89 crx??
Old Nov 8, 2002 | 10:54 AM
Shawn D's Avatar
Default Will a 92 integra dash fit in the 89 crx??
I came across a 92 integra dash that i wana put into the rex cause i think it would look very good. I know it would be hard as hell making new mounting points for it but if anybody here has done this kinda thing then some info would be greatly appreciated. pics would be good too. Also how does the dash fit up to the crx door panels...Cutting needed?
Thanx,
-Shawn D
Old Jan 29, 2004 | 10:33 AM
benn2k's Avatar
Default Re: Will a 92 integra dash fit in the 89 crx?? (Shawn D)
would like to know to?
Old Jan 29, 2004 | 10:36 AM
manson's Avatar
Default Re: Will a 92 integra dash fit in the 89 crx?? (benn2k)
i would think it wouldn't work at all. you will need to do alot of cutting and plumbing for the vents to work plus it won't match the door panels and then the dash is a few inches bigger than the crx one....its alot bigger. it will also come towards you alot more maybe by a 3-5 inches. if you want to do it get a tape measure and start figuring it out.
personally i would think its not worth it. but its your car so build away.
Old Jan 29, 2004 | 11:29 AM
B1TEM3's Avatar
Default Re: Will a 92 integra dash fit in the 89 crx?? (mansonclubpuir)
i agree with mansonclubpuir,
the width of the 92 integra frame also bigger than our car, aligning the dash would be a challange
Old Jan 29, 2004 | 01:14 PM
YumVTEC's Avatar
Default Re: Will a 92 integra dash fit in the 89 crx?? (B1TEM3)
it has been done, but like everyone has said it's a pretty custom job. hell, i've seen a 94+ integra dash in a CR-X. anything is possible.
Old Feb 2, 2004 | 02:47 PM
B1TEM3's Avatar
Default Re: Will a 92 integra dash fit in the 89 crx?? (YumGTR)
94 + integra is smaller overall width than the 92 integra. it probably would fit better. The 92, it would take tremendoues effort just to make it fit. Besides, it would be a costly and time consuming job, i would prefer spent the money for other parts. if its free , then you can do whatever you want.
Old May 24, 2004 | 09:08 PM
derekellison's Avatar
i have a 92 ls dash in my 91 si the thing bolted right in except a few bolts you half to make fit. the only thing that is giving me a problem is the door pannels im cutting the bottom and rear off of the crx and fiberglassing them onto the upper front of the integra door pannel. almost everything ive swaped from the 92 integra onto the 91 si has bolted right up. with the exception of motor mounts i havnt had any problems except the door pannels.
here is a list of everything ive already put in my crx.
engine swap
dash
front & rear complete suspension including front under carrage
steering assembly
power stering
ac
everyone says thing wont fit but most will
dracocrx
Jan 28, 2009 07:30 PM
chuisek9
Jan 28, 2008 04:28 AM
xsellxoutx
11
Dec 29, 2003 09:46 AM
NisAznMonk
Jan 13, 2003 09:55 PM
Another B16
Nov 12, 2002 11:31 PM
