Wheel hub assembly for EG6 hatch
Old Sep 25, 2016 | 07:00 AM
TheShiftyHaze's Avatar
Default Wheel hub assembly for EG6 hatch
So the hubs on my 92 hatch are worn out and I need to replace all four, however I am confused on what hubs to get since its the JDM civic not a NA civic. It has rear disk brakes as well, not sure if thats stock or swapped in. Any help is much appreciated.
Old Sep 25, 2016 | 11:19 AM
Former User's Avatar
Default Re: Wheel hub assembly for EG6 hatch
Why do you think the hubs are worn out?
Old Sep 25, 2016 | 11:28 AM
Thanks for the diagrams but they do not help me. The shop I took the car to said the bearings were shot, also the threading for the wheel studs on the hub are stripped so the wheel studs just spin freely in the hub so I'm looking to replace the bearing and the hub.
Old Sep 25, 2016 | 01:08 PM
98civdx's Avatar
Master Detailer
Get a second opinion on the car.
Old Sep 25, 2016 | 01:15 PM
No need to replace the hubs just because studs are bad. Studs are cheap. So again, why do you believe the hubs are bad?
I posted the diagrams because you seem not know the names of the required parts or which ones, if any, are bad.
As mentioned, get a second opinion from a reputable shop. You don't need the expertise of this forum if you just choose a good shop.
Old Sep 25, 2016 | 01:17 PM
Its a waste of time, it is very clear i need new wheel hubs, all the studs spin in the hubs because the hubs are stripped. I would just like to know which ones i need.
Old Sep 25, 2016 | 01:20 PM
You're wasting our time. Locked.
EK_EG_DC
Mar 16, 2009 08:54 PM
killerpenguin21
Nov 14, 2006 12:36 PM
Tyson
22
Jul 13, 2002 03:45 PM
jdm_ef9
Mar 10, 2002 12:26 PM
InfamousRS
Feb 11, 2002 09:36 PM
