What does a bad input shaft bearing sound like?
Old Sep 25, 2016 | 06:59 AM
masospaghetti's Avatar
Default What does a bad input shaft bearing sound like?
I have an intermittent faint chirping / squeak coming from the transmission bellhousing area. Using a stethoscope it's by far the loudest on the clutch release arm. If I put any pressure on the clutch pedal the noise stops.
Sound like my ISB going bad? Will I get fair warning before it explodes?
92 Accord w/ H23A1 and M2S4 transmission. Thanks
Old Sep 25, 2016 | 03:35 PM
holmesnmanny's Avatar
Default Re: What does a bad input shaft bearing sound like?
take the two 10mm bolts off the slave cylinder and put some grease on the ball tip of the piston and see if the sound goes away
Old Sep 25, 2016 | 04:47 PM
Hmm so maybe the pivot point is squeaking when there's no pressure? Makes sense, good idea. I'll try that.
jdsande3
Sep 15, 2013 11:57 PM
g0tgot
Jul 2, 2012 12:04 PM
2000-em1
Transmission & Drivetrain
Dec 29, 2011 05:52 AM
reyrey2006
Aug 5, 2008 07:55 PM
Ek9Max
Mar 15, 2005 07:19 PM
