H22a1 Built for turbo aem ems turbo kit etc
Old Sep 23, 2016 | 12:10 PM
customs-25's Avatar
Default H22a1 Built for turbo aem ems turbo kit etc
I am selling the remaining parts from my 98 prelude, below is a list of parts, I also have alot of other smaller chassis parts from the car let me know what you need.
H22a1 built for turbo darton mid sleeves, cp 88mm pistons, eagle rods, arp studs, balanced crank, manual tensioner, aem cam gears, new oem valve train, I have the reciept for the build, it was done years ago but it only has a few thousand miles on it and it was run at only 6 psi 245hp I have the dyno sheet $1200 firm pickup only in Livermore ca 94550
H22 head off above engine with new oem valve train, aem cam gears, h23 blue valve cover $500 shipped
H22a1 block with darton mid sleeves no crank rods, pistons or oil pan for $800 shipped
aem cam gears $125 shipped
Turbo kit garrett .60 .63 turbo journal bearing drag manifold painted silver, intercooler with piping, greddy blitz bov, turbonetics wastegate, downpipe, filter, mac boost solenoid, turbo blanket, ss oil line, oil hose to oil pan, etc for $1200 shipped
garrett journal bearing .60 .63 turbo low miles 5 bolt $400 shipped
Rc injectors 550cc with plugs $220 shipped
Aem series 1 ems $500 shipped was used in a 98 prelude
Cp 88mm pistons turbo low compression ratio $250 shipped
Timing cover $50 shipped
Thermostat and housing $50 shipped
H22a4 distributor with plugs and coil $70 shipped
Td61 distributor with external coil like new $70 shipped
Harness to delete crank angle sensor and use a internal coil distributor $50 shipped
Crank timing gears with countershaft and timing belt and crank angle sensor $60 shipped
Old Sep 30, 2016 | 05:20 PM
customs-25's Avatar
Default Re: H22a1 Built for turbo aem ems turbo kit etc
updated
Old Oct 16, 2016 | 10:49 AM
customs-25's Avatar
Everything is still available prices lowered
Old Oct 27, 2016 | 05:31 PM
dwayne porter's Avatar
What's the best price on the h22a4 sleeved block can I get a contact number I am real interested
Crank timing gears with countershaft and timing belt and crank angle sensor $60 shipped[/QUOTE]
crxjake
Apr 12, 2015 05:08 AM
S2KRIDERAP2
May 22, 2010 08:09 PM
dunerider
Honda Motorcycles
Feb 8, 2007 07:36 PM
Todapwr
Mar 1, 2004 12:14 PM
