Suspension & Brakes Theory, alignment, spring rates....
Can't find the correct hub for my rear spindle
Old Sep 21, 2016 | 05:49 PM
portablenarc's Avatar
Default Can't find the correct hub for my rear spindle
ok so I bought a rear disc conversion from a guy. He said it was off a 94 integra. I installed the trailing arms and all along with new brake lines only to find out the hubs are wrong! When I put the lock ring on and tighten the axel nut the hub has about a quarter of an inch of inward and out ward play. Now I went to the store and tried every hub from civic to delsol to integra. I can't find the right one. It seems to me he spindle is too long (measures out to an 1 7/8 from the face of the knuckle to the end of the spindle). If anyone has some insight on what hub it could be I'd greatly appriciate it! Thanks.
Old Sep 22, 2016 | 12:15 PM
98civdx's Avatar
Master Detailer
Default Re: Can't find the correct hub for my rear spindle
Are you using the washer underneath the axle nut?
#2 on here. I know it's a drum diagram, but you should get the idea.
http://estore.honda.com/honda/parts/...=B++19&dl=#002
Old Sep 22, 2016 | 01:21 PM
[QUOTE=98civdx;51061942]Are you using the washer underneath the axle nut?
Honda online store : 2000 civic rear brake (drum) (1) parts[/QUOTE
yes I do have the washer under the axle nut.
littleblue
Oct 2, 2009 09:06 AM
mrmanuke
Nov 29, 2006 10:49 AM
