what's the stock 94ex wheel weight?
it thought that it would be almost the same as the prelude si wheels. about 22 lbs. are you sure about that? anyone knows any site for wheel weights?
I would say ~15-17lbs on the 7 spoke accord guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KGAccord »</TD></TR><TR><TD CLASS="quote">16.5lbs is what I found.</TD></TR></TABLE>
If this is for stock 15in, would it really matter/make sense to get some slipstreams in 16in when they are only 3lbs lighter ? I'm asking because i want to keep a stock look for the car but i don't see the point in paying $500 for 3lbs lighter and 1in bigger. Can anyone verify the point in this for me ?
Well as helpful as that knowledge is, i was looking for something deeper into the realm of " Would 3 lbs lighter 1in larger slips make such a difference in performance " ?
the advantage of 16's thou is many more tire selections. And if you get the slips in a wider than 5.5" size, the tires will sit better.plus you can sell the EX wheels to makeup some of the cost of the slips.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepersOwn »</TD></TR><TR><TD CLASS="quote">Well as helpful as that knowledge is, i was looking for something deeper into the realm of " Would 3 lbs lighter 1in larger slips make such a difference in performance " ?</TD></TR></TABLE>
the 16s are a 7 inch wide wheel which is better along with running a smaller sidewall so your cornering ability should be better. straightline speed wise, probably won't do anything.
i was considering 16 inch subzeros myself, but i decided that 16s won't look good and i'd rather keep my sleeper look.
cool, so i'll keep the stockers on until i finish with the sleeper theme. I wanna shave off the moldings and emblems, 1.5 or 1.75 lowering ( still undecided ), and 17" velox rims ( hell they're 11.5 lbs :-D ). All of this after i finish kicking some serious *** as a sleeper...Thanks Guys !
yellowturbo
11
Oct 17, 2007 04:37 PM
ViZ
Jan 3, 2004 08:47 PM
