91 CRX Si Build- CoCo
Old Sep 19, 2016 | 09:35 PM
Chase1Ratliff's Avatar
Default 91 CRX Si Build- CoCo
What’s up everybody. I’ve been a member on here since 2013 but never posted anything till today. I have a build thread that I started on CRX Community like a week after I got the car. I will summarize it all on here for you guys and try to clean it up a bit from my 17-year-old self (now almost 21). Here is a link to the thread on CRX Community if you would like to take a look. CRX Community Forum ? View topic - 1991 CRX SI Build
I purchased the car with the help of my dad in June of 2013. I couldn’t think him enough for helping me get one of my dream cars. A CRX a dream car? I know it’s crazy. Here it is the day we purchased it,
First thing that needed to be done was change out the badly dented fenders for almost perfect fenders. This made the front end look way better, since the lights were all out of whack.
Next was to fix the play in the shifter, you could move the shifter a few inches while in gear. I went with the Wicked Innovations zero play mod which made the world of a difference. They just weld in a new U-joint.
Bought a K&N intake to get the car on the road because it was missing when I bought it. Had to modify it with a straight piece from Advance to get it to fit right.
After that the CAI (more of a ram intake) interfered with the battery tray so that gave me a reason to relocate the battery, I used the PW: JDM relocation kit. With the current stage of the build I will be relocating to the boot.
Then I needed even better shifter feel and went with a Skunk 2 weighted shift ****. Also an extender to get it closer to me. This changed the feel more than I would have thought, makes banging gears in the baby Z6 even better.
Decided I should get some before pictures done for the start of the build. Found a guy in Parkersburg to do them for me, Glad I used him because he has grown into a very good friend that also has an EF. We’ve been giving each other motivation to pick it up on our build ever since.
Fast forward probably 2 years and I’ve finally got my butt in gear on the build. Was at college but dropped out for a job opportunity I couldn’t pass up. I am now a NDT Technician, and it has given me the resources and the money coming in to build not just the CRX but also my B5 Avant. Will be purchasing another project car here soon for a drift build. I did own a 240sx as well as the CRX in high school but chose to sell the 240 for college money.
SO! It all started at just changing the wheel bearing but thought to myself it’s now or I’ll just keep throwing it off. That’s when this happened
First I completely tore the front end apart for FULL suspension upgrade and overhaul. Then I thought how bad the engine/ bay was gonna look after all the new suspension was thrown on. So that came out also.
All the stock stuff was powder coated. Everything is either OEM or upgraded. Here is a list of suspension mods and stock replacement. Steering rack was also refurbished by me.
· Skunk 2 UCA
· OEM Hubs, Wheel bearing, and tie rods
· ARP Extended Studs
· Progress Coilovers 350/350
· Downstar Bolts all the way around
· Hardrace Bushings
Then it was time to get the engine bay painted. It came out pretty good.
While it is all out I decided to build a High Comp Z6. Close to 12:1 Compression. Heres a list of all engine upgrades and OEM replacement. Painted the Transmission and Block as well.
· PG6 Pistons
· ARP Rod bolts on stock rods
· All OEM gaskets
· OEM Bearings
· ARP Head Studs
· Oil Strainer
· Water Pump
· Timing Belt and everything needed to replace
I think that is everything in a summary. Now you are all up to date. It’s nothing crazy yet, but I hope to have it looking pretty good in the next year or so. It needs paint more than anything and that would really set it off.
Old Sep 21, 2016 | 05:24 AM
Old goat's Avatar
Default Re: 91 CRX Si Build- CoCo
Nice, looking good.
Old Sep 21, 2016 | 04:16 PM
Originally Posted by Old goat
Nice, looking good.
Thanks!
Old Sep 22, 2016 | 06:47 AM
Drummerkid51's Avatar
The info before our two pictures almost made me tear up. haha Can't wait to get these things back on the road!
Old Sep 22, 2016 | 04:46 PM
That was the plan lol. Oh dude so ready to drive this thing.
Old Oct 7, 2016 | 09:55 PM
Sorry for the lack of updates. Still waiting on my stuff to come in from AFH to finally put my engine back together. I'm currently working 6 12's so I'll be able to throw some more money at the car soon!
Old Jan 30, 2017 | 11:42 AM
Finally an update! I'm pretty excited to get her back on the ground in the next week or two. Well then it's time for the rear to be put up and everything rebuilt back there. Anyways here's some pictures,
First I installed my innovative traction bar
Then rebuilt my calipers and was able to throw my rotors and pads on
I am running Hawk HPS pads and Brake performance rotors. They come with a coating to protect the non contact parts from rusting. I've been running them on my Audi for over a year and not one spot of rust has showed up on them, they sell every type of rotor (slotted,dimpled,drilled) so go check them out!
Engine will hopefully be put back together in Feb. and thrown back into the car when I order my engine mounts. Other than that it's just little stuff I need to tidy up in the front. Also have to tuck wiring and order a CJ's harness.
Old Jan 30, 2017 | 12:06 PM
ssmrico's Avatar
very nice
Old Feb 1, 2017 | 07:04 AM
DWP_Racing's Avatar
THIS LOOKS LIKE ITS GOING TO BE A GOOD BUILD... FOLLOWING
Old May 11, 2017 | 05:08 PM
Never really update you guys anymore. So here is what has been going on lol.
Well first things first. Picked up a Cressida for a drift build which I'll be starting when my Audi sells.
And I got a new Daily. 2011 GTI, Stage 1 and a CAI
Back to the CRX. Got the engine together and back into the car! Finally!!
Getting it out together.
All finished up.
Went with CC lightened flywheel and Exedy stage 1 clutch.
Finally back into the car after months and months!!
How it's sitting as of the other week. Currently have the radiator and a few other things installed
I was gonna run the chase bays fuel line kit. But decided I didn't want a clamp at my fuel feed. So I went with the Radium fitting that bolts straight to your existing nut.
Oh and here ya go
Rear suspension will be started on in the next few months and won't take near as long as the front end has. So expect an update around then lol.
Old May 11, 2017 | 06:10 PM
~sp33~'s Avatar
EFB055
Nice progress, and love Cressidas.
Old May 11, 2017 | 06:26 PM
Thanks! I plan to 1J swap it then skid it.
Old May 14, 2017 | 07:10 AM
Bently_Coop's Avatar
Steve at Heart
Solid updates, those fuel line adpaters sure make it easy. I used one from eBay.
Which Header are you using? How is clearance underneath?
Old May 15, 2017 | 03:45 AM
Yeah they make it a lot easier. I'm running the DC sports Header, clearance is good It sits close to the oil pan.
Old May 19, 2017 | 07:22 AM
bbarbulo's Avatar
Lot of talent and patience here. Great build!! I do see one problem, and it isn't so much a 'problem' really... I deal with it too. The car 'attention deficit disorder'. I say this from experience, having been a dozen cars deep in my ownership at any given time. It started off innocently enough like you, but unnoticed it gets out of hand. I've had cars untouched for years because I bought another, and another and another... I've just sold off 4 of the higher end cars and I still have 8 left, with barely enough time to work on one or two. That said, I do like your choices.
Old May 22, 2017 | 05:15 AM
Thanks! I have had a lot of help and a lot of time researching to get this far lol. Yes it is a problem I currently have 4 cars and I'm trying to sell 1 to be able to work on the Cressida a bit. I'm stop myself to buy any other cars until these are done lol. Even though I really want to start a cafe racer build as well.
Old May 22, 2017 | 09:57 AM
BETaEF's Avatar
Love the build. Cant wait to see more. CRX's are amazing little cars! I just picked up a 90 ef hatch si. Kids couldnt ride in back of rex so i sold it.
Keep updates coming!!
Old Jun 5, 2017 | 08:19 AM
I'll update as much as possible. Put a new heater core in over the weekend. Got it from advance and it fit like ****, had to bed the lines to get it to even line up. Going to get a used OEM one I guess. I update on my YouTube channel, it's been slow on there but I plan to upload more frequently.
https://youtu.be/LyTSsQroh7A
Chase1Ratliff
Oct 3, 2016 09:32 AM
Tomtheman70
22
Oct 27, 2009 06:11 PM
crx2p450
Nov 19, 2006 08:40 PM
BridgeCRX
34
Aug 18, 2003 01:05 PM
RAWbertCuBus
Oct 21, 2002 06:59 PM
