Suspension & Brakes Theory, alignment, spring rates....
Bump steer issue
Old Sep 19, 2016 | 07:07 PM
Android Jr's Avatar
Default Bump steer issue
Greetings fellow JDM peeps, I have an issue with bump steer on my '92 EG6. It's lowered with adjustable coil overs (skunk2 pro 2) there is very little clearance from the fender and wheel, no rubbing tho, even when hitting bumps. I've heard/read about installing the tie rod ends upside down. To do that the tappered hole has to be drill wider to fit OEM style tie rod ends. Or another option are the hardrace tie rods, I find very little info with reviews on them. My question is, what are you guys doing about the bump steer issue? Using any custom made tie rods out there? Your info is greatly appreciated
Old Sep 21, 2016 | 03:44 PM
FlewByU352's Avatar
Default Re: Bump steer issue
Originally Posted by Android Jr
It's lowered with adjustable coil overs (skunk2 pro 2) there is very little clearance from the fender and wheel.
Here is your problem.
portablenarc
Suspension & Brakes
Oct 10, 2018 10:29 AM
jjr
Jun 17, 2013 01:59 PM
greyzone
Suspension & Brakes
14
Aug 10, 2005 10:15 AM
miamidamian
Jun 10, 2005 05:05 AM
rodvang
Apr 19, 2005 12:27 PM
