clutch pedal stays on floor for a little bit
hey guys,
my clutch pedal sticks to the floor just a little then comes back up. can anybody here tell me whats wrong with it? thanks
check the fluid and possbily bleed the lines. same thing happened to this dude we met at nopi , we bled his line and worked fine from t here. . . assuming its hydo , if its cable adjust the tenstion
[Modified by itr206, 11:38 AM 11/8/2002]
[Modified by IntegraLStuner, 12:44 PM 11/8/2002]
thankfor the info guys but sopmething worse happened today i was driving home and all of a sudden i lost power at 4 it was like i was revving in neutral. when slowly got home i realized that every time i revved past 3k and then put it into neutral the idle gets very lumpy. please if any one can help about this id be greatly appreciative. i think i may have hydrolocked.
Did you drive through a large body of water? I did not notice anything about excessively wet conditions in your original post... Perhaps if you posted all of the conditions leading into the problem we could help more.
I had the similar problem too. Try and check to see if your clutch master cylinder is leaking any fluid. If it is that could be your problem. For now, i would check the fluid and then bleed the clutch out.
Yep, first thing would be to check the fluid.
This is stupid, but you never know...also check the floormat to see if the clutch is catching on it, slowing its "upstroke."
