Sputtering!!! help !!! Please!!!😢
Old Sep 16, 2016 | 02:58 PM
SiRWaGoN's Avatar
Default Sputtering!!! help !!! Please!!!😢
I've been searching for days on forums and have found many helpful ideas but nothing is working.. Even my auto tech teachers advice didn't work
B16a-from a teg xsi...... Swapped into an 89 civic wagon.....Engine is sputtering when I try to just cruise along and accelerate ... Goes away when more throttle is applied (doesn't have to be WOT)....map sensor , plugs wires rotor and cap all replaced .. Doesn't appear to be injectors or fuel pump ..
evap/carbon canister/solenoid isn't connected..... Also I'm getting no cel
I unplugged o2 sensor for cylinder 1-4 and it went away ... I plug it back in and unplugged o2 sensor cylinder 2-3 and it went away .. Comes back with both plugged in ... Help me please lol
Old Sep 16, 2016 | 03:55 PM
tamboo's Avatar
10 Year Member
Default Re: Sputtering!!! help !!! Please!!!😢
could be an exhaust leak ahead of the sensors is freaking them out.
Old Sep 16, 2016 | 04:16 PM
SiRWaGoN's Avatar
The manifold and gasket appear to be intact ..
Vtec works fine and wiring is done correct I double checked
Old Sep 17, 2016 | 09:57 AM
upnsmoke's Avatar
I would check your throttle position sensor if you haven't already. If it tests good you may try adjusting it. I'm working on an mpfi swap on my d15 and having a similar issue to yours. I was able to improve on it by adjusting the tps so the voltage is about .7 at closed throttle. Not correct, but it has helped my driveability while I work on isolating my issue. I'm going to grab another sensor as well as I believe mine may have a bad spot.
SiRWaGoN
Sep 17, 2016 03:54 PM
S2KILLA
Jul 7, 2010 08:30 AM
LimaBean
Jul 26, 2009 08:39 PM
outomyelement
Apr 3, 2009 10:47 PM
