e brake button hard to press (00 ex coupe)
Old Sep 16, 2016 | 01:25 PM
DeviousJunez's Avatar
Default e brake button hard to press (00 ex coupe)
My e brake button is hard to press down , like literally i have to have both my thumbs on the e brake just to press it hard down. How can i fix this?
Old Sep 16, 2016 | 01:42 PM
Former User's Avatar
Default Re: e brake button hard to press (00 ex coupe)
Not sure, maybe try some WD40?
Old Sep 16, 2016 | 01:53 PM
ill try it once i have my radiator fan here then make a pit stop at autozone to buy a wrench i need then look for wd 40 and some coolent
Old Sep 16, 2016 | 07:49 PM
mk378's Avatar
You aren't trying to release the brake just by pressing the button, are you? Because it doesn't work that way. You need to pull up on the handle while pressing the button to release the pressure on the latch. Once the button goes in, hold it in and lower the handle.
Old Sep 17, 2016 | 05:43 AM
chrysler kid's Avatar
I've had a similar problem, I think it got so bad that I popped the handle over the button.
Anyways wd40 or any other lubricant spray fixed m problem
Old Sep 17, 2016 | 10:47 PM
oneheadlight's Avatar
I've had this before, just pull the e-brake/parking brake handle off and file open the hole more where the push button release is. I had this happen before and got so tired of it catching I just filed it more, no more issues.
Old Sep 18, 2016 | 02:28 AM
Do i just spray wd40 on the button and let it seep into the handle?
Old Sep 18, 2016 | 04:36 AM
tony_2018's Avatar
Fish Twig
You should be able to hit it from the back
Old Sep 19, 2016 | 12:02 AM
What do you mean i should be able to hit it from the back?
jlh911
Jul 18, 2012 10:33 AM
RedGSR
Sep 22, 2005 08:50 PM
nemesismachine
Jul 21, 2004 07:00 PM
ciVick_EX
Apr 29, 2004 09:20 AM
brycerocket
Apr 8, 2003 06:30 AM
