Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Max AC, no increase in blower air flow?
Old Sep 16, 2016 | 06:04 AM
WG08051's Avatar
Default Max AC, no increase in blower air flow?
Good morning,
I am new here & to Honda. My wife's car is a 2006 Honda Civic. She bought it new & it still has low mileage (105K). I just replaced the AC clutch & the air seems to be fine - cold enough. The air flow from the blower seemed to be low - so, I replaced the cabin air filter. That seemed to make a big difference. However, there is no difference in the air flow from ac to max ac. The lower speeds work as they should & the cooling is fine. I assume this is not normal & the fan speed should increase from ac to max ac. And, at maximum speed - the resistor pack (again, assuming this is what it is called) is bypassed for full power. So, I am a little confused... Is the "bypass" done internally or externally? If internally, then it would make sense to me that the resistor pack could be the problem - if not, then it would have to be the connection or the blower motor itself? Any other suggestions? Should the fan speed increase from ac to max ac for a 06 Civic? Any input would be greatly appreciated.
Thanks,
Bill
Old Sep 16, 2016 | 01:45 PM
holmesnmanny's Avatar
Default Re: Max AC, no increase in blower air flow?
all the Max AC button does is automatically turn on vent and recirculation. If it's already on those settings it won't make a difference so it's working normal.
Old Sep 16, 2016 | 03:19 PM
WG08051's Avatar
Thank you for the information. My wife doesn't remember - but, thought it may have increased. So, all is fine after all.
Again, thank you.
ryanb14
Honda CR-V & Element
Jul 23, 2022 10:59 AM
Strez
Jun 9, 2015 05:16 PM
digital sol
Aug 7, 2007 02:07 AM
Ha7chB4cK
10
Jul 3, 2005 10:28 PM
