Engine overheating and burning metal smell
Old Sep 13, 2016 | 11:08 AM
DeviousJunez's Avatar
Default Engine overheating and burning metal smell
So here it goes, so my 00 civic coupe d16y8 started heating up, i opened the hood and anti freeze was leaking and burning out of the radiator cap (which caused this visible smoke) now i went to the mechanic and he told me FOR SURE that i needed to replace my radiator..guess what? 15 minutes later AFTER i paid 200$ for the radiator to be replaced with a new one i started smelling a smell of burnt metal (like the kind when you use a saw against metal and makes that smell..also the cold and hot gauge started going to hot (Im going back to the mechanic tomorrow the same one) PLEEASE HELP SHES MY DAILY!
( I don't know if turning the a/c on effects it but my mom turned on the a/c right after the fix was done of course they made us wait for the fluids to be just right)
Other issues
- The car has high idles that go from 1k to 2k that sometimes go to each other up and down and sometimes in between.
Old Sep 13, 2016 | 11:20 AM
Former User's Avatar
Default re: Engine overheating and burning metal smell
When engine is cool remove the radiator cap, and top off the radiator and reservoir with 50:50 coolant.
Then properly bleed the cooling system, which your mechanic failed to do.
https://honda-tech.com/forums/honda-.../#post39830585
I hope you did not destroy your engine.
Don't bring your car to that useless mechanic ever again. And submit a negative YELP review to help others from suffering from the same misery.
Old Sep 13, 2016 | 12:09 PM
Default Re: Engine overheating and burning metal smell
Thanks! and i will! also i hope not :/ or my mom would get stressed because thats the only car we have and for certain if the engine is dying , im still keeping her but anyways ill need too buy some coolant then. so by 50 50 you mean 50 water 50 coolant mixed correct?
Old Sep 15, 2016 | 05:10 AM
Default Where can i buy the right side fan and what is that fan called?
So turns out the fan on the radiator of my civic 2000 was burning and it was pin point because i smelled the same burning metal smell on that fan.
also where can i find a tutorial on replacing the right passenger side fan?
Old Sep 15, 2016 | 05:14 AM
testify's Avatar
On vacation
Default Re: Where can i buy the right side fan and what is that fan called?
Burning smell? How did you determine its from the fan?
Old Sep 15, 2016 | 05:40 AM
The motor fan wasnt in place , like its tilted and the fan was just loose i literally could wiggle it around like a doll. i also smelled the fan and my hand and it was the exact smell.
Old Sep 15, 2016 | 05:45 AM
testify's Avatar
On vacation
You just unbolt and unplug the fan, get a new one, bolt and plug the new one in place, and you're done.
No need for a tutorial. It's a 5 minute job.
Old Sep 15, 2016 | 05:52 AM
https://www.go-parts.com/ho3115101-1...y-1-6l-l4.html
That fan looks ok right? It looks a bit different
Old Sep 15, 2016 | 09:02 AM
fcm's Avatar
fcm
Old Fart
Performance rad has direct replacements... https://shop.performanceradiator.com...product_id=572 more money but way less then OEM and a direct fit.
Old Sep 18, 2016 | 02:42 AM
Default Anti freeze question and Timing belt
Is 50/50 anti freeze coolant ok to use every time to refill the reservoir & radiator if low? or go full on antifreeze? (What kind of coolant can i get that is safe for my 00 civic automatic ex coupe d16y8? Because im the third owner and i don't have a owners manual also i don't know if this changes the circumstances but i live in nyc so there winter (snow) and summer here ) , Also when do i have to change my timing belt? shes been sitting since 2003 im guessing since that was the last registration date sticker seen on her , I wanna change it to that blue timing belt i see people have ( I don't know the name and where to buy a legit one ) and finally is it bad if i leave the first cover that covers the cam? & where can i get a legit michimoto radiator?
Old Sep 18, 2016 | 04:35 AM
tony_2018's Avatar
Fish Twig
Default Re: Anti freeze question and Timing belt
There is no such thing as full on antifreeze. If you buy the undiluted antifreeze you need to mix in as per instructions, 50% antifreeze and 50% distill water.
Old Sep 18, 2016 | 05:43 AM
Please do not create anymore new threads until you post solutions for your many previous threads and car problems.
Posting solutions is a way for you to give something back (contribute) to the forum.
Old Sep 18, 2016 | 06:31 AM
oh sorry
vtec2017
Mar 18, 2017 04:24 PM
halo2k7
17
Jul 23, 2008 09:57 PM
Shintakun
Honda Civic (2001 - 2005)
Jan 26, 2008 07:44 PM
88EFhatch
Jul 12, 2005 05:48 PM
Chemicalviper
Nov 25, 2003 08:44 AM
