P28 ECU ?
Where are you guys mounting your p28's? My friend has his under the mat on the passengers side up by the firewall. His is very sensitive if you tap it the damn Check engine light comes on. I'm gonna get one but don't want it destroyed by passengers. Any help is appreciated. Thanks
Over on the passenger side under the carpet and plastic piece just before the door. The plastic piece doesn't snap on all the way though because of the bulcky conversion harness.
it should fit where the ecu was before you swapped doesnt it? if not im sure you can squeeze it behind that kick panel . i dunno i was gonna swp amine this weekend , ill see for sure.
Its in the same spot its just it has the conversion harness adds this huge bundle of wires and makes it so the plastic piece that used to snap over the ecu not fit exactly.
sevenfc
Jul 23, 2009 05:57 PM
Seedc2
Jan 4, 2009 04:03 AM
