D16Y8 oil leak
Old Sep 11, 2016 | 02:40 PM
hondacrx2's Avatar
Default D16Y8 oil leak
I am am trying to find the cause of these engine leak on the front of my engine. I replaced the Vtec seloniod and distributor O-ring. It almost looks like the oil is coming from the corner of the head gasket. However, coolant is still green and oil has no coolant in it. Any ideas. It's not coming from under the distributor.
Old Sep 11, 2016 | 02:41 PM
Former User's Avatar
Default re: D16Y8 oil leak
Start by sealing the VTEC solenoid gaskets with HondaBond and replacing the distributor O ring.
Old Sep 12, 2016 | 08:43 AM
FactionR's Avatar
Default Re: D16Y8 oil leak
Just did all the seals on my y8 recently to stop leaks in the same area. Dizzy o-ring, vtec solenoid seals (all of them) and valve cover gasket. My source ended up being a brittle and cracked vtec solenoid gasket in the between the two parts of the solenoid.
Old Sep 12, 2016 | 08:54 AM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Clean up all the oil first. Then keep an eye on it over then next few days. That's really the only way to find the source of the leak.
eH.
Old Sep 12, 2016 | 12:31 PM
White_EG1's Avatar
To me it's as simple as taking off the dizzy or the vtec solenoid cleaning it off and looking at the gasket any small brittleness, fraying, or tears then I'd replace.
EDIT: If the leak still persists, do a compression test on the motor if the hg is leaking itll show.
F20Cdriver
23
Feb 24, 2020 11:46 AM
Vague
11
Jan 2, 2016 08:21 AM
David Guevara
Nov 26, 2015 06:15 PM
Travlash
13
Apr 29, 2015 07:58 PM
LoGaN-VanG
13
Jan 12, 2014 04:40 PM
