Hi all! I have a 2004 Accord EX V6 that's been having trouble with the ABS braking system. I haven't seen the ABS indicator light come on, but have noticed the car seems to take much longer than it should to stop in slippery conditions when the ABS is engaged. I wanted to check the resistance of the speed sensors from the main control module, but can't seem to figure out the pin configuration to make sure I'm checking the right pins. Here's a pic of the connector:
I attached a .pdf of the wiring diagram I found. My question is - Is this the right diagram, and how are the pins on the connector numbered. Any help would be greatly appreciated!
