ef6 1st Gen DOHC ZC swap HELP!
Old Sep 10, 2016 | 11:28 PM
JDM rexy's Avatar
Default ef6 1st Gen DOHC ZC swap HELP!
Hi i need some help with my with a 1st gen dohc zc swap into a ef. I have a 1989 civic gti ef6 (NZDM) that im trying to put a low k's 1st gen zc into it but im having trouble with the intermediate shaft. Im using my stock L3 gearbox and stock wiring harness. I already know that i need to modify the passenger side engine mount and the wiring to the dizzy.What sort of intermediate shaft do i need and if i remove all the vacuum lines will the motor run flat?And also what timing belt do i use?
Old Sep 11, 2016 | 07:57 AM
4drEF's Avatar
Keyboard Humorist
Default Re: ef6 1st Gen DOHC ZC swap HELP!
You should get the shaft that originally came with the transmission.
why would you want to remove vacuum lines?
Old Sep 11, 2016 | 01:30 PM
JDM rexy's Avatar
The motor didn't come with a transmission and my intermediate shaft wont bolt up to the block because it catches on the oil filter.I want to remove some of the vacuum lines because i don't have the black box.
Old Sep 11, 2016 | 02:44 PM
theotherchris's Avatar
If your gearbox was originally for a sohc engine then the intermediate shaft will not fit in the trans
teh_touch
Transmission & Drivetrain
Jun 22, 2018 09:50 PM
ludefanatic
20
Dec 5, 2007 04:22 PM
temporarysuicide
Oct 31, 2006 12:48 PM
1badrex
Jun 12, 2003 12:18 PM
