EM1 rear bumper sagging
What year and sub model, 2 door 3 door or 4 door DX, EX. CX SI, VX or LX???
Step back a little for the pixs.
I am guessing missing or damaged clip, [bumper face] mounting bolts or bolt holes damaged or missing "clips", [face hangers] loose/broken/bent bumper beam.
Need more info on MM&Y of car, but all bumper clips are eventually hung on the bumper beam and screwed and clipped to the body panel, you will have to remove the bumper face stiffener, [section above the bumper clip] to access the mounting bolts remove the mud flaps, [if you have them], remove the two screws at top front of bumper clip attaching clip to body panel then "unclip" the bumper face from any remaining hanger clips and remove the bumper face, [lots easier with two people] then inspect everything replace any broken/damaged hanger clips. 94
It's a 2000 SI Coupe. I'm going to replace the 2 self tapping clips as one is damaged, but what other parts are you suggesting? Do you have a diagram?
