96 civic d16y7 - Many questions
Old Aug 3, 2016 | 12:40 AM
rodz's Avatar
Default 96 civic d16y7 - Many questions
D16y7 with y8 intake manifold I was driving and my car everything was fine until my car started to over heat so I got to my house and I put Water and let it cool down for boout an couple of hours and when I turned the key on to starte the main relay started tapping and it was kinda hard to get it running again but when I did the car wouldn't rev over 2000 RPMs and when I drive it would take a while to pick up and when I come to a stop the car will idle up and down please I really need help
Old Aug 3, 2016 | 04:48 AM
mk378's Avatar
Default Re: d16y7 overheats, won't rev over 2K rpm, hesitates, hunting idle
With your next engine, don't drive overheated.
Check timing and compression, but given this history it's likely the engine is completely toast.
Old Aug 3, 2016 | 08:06 AM
rodz's Avatar
Well I didn't really over heat that bad it was just because my fan want kicking on and once I started to set it over heat I was down the street from my house but is weird because after I let it cool down and went to go start it that's when it started acting weird I really don't think I have a bad head gasket
Old Aug 3, 2016 | 08:51 AM
Former User's Avatar
What was the needle reading and how long did it stay there?
Old Aug 29, 2016 | 03:00 PM
rodz's Avatar
Default 96 civic d16y7 takes forever to accelerate
Hey everybody I really need some help with my Honda Civic d16y7 for some reason it takes forever to accelerate it was running fine one day and then the next day it started running shitty it takes forever to catch speed I really don't know what to do anymore
Old Aug 29, 2016 | 08:13 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default re: 96 civic d16y7 takes forever to accelerate
auto or manual? how many codes thrown?
Old Aug 30, 2016 | 06:04 AM
Default Re: 96 civic d16y7 takes forever to accelerate
Post the CEL codes.
Old Aug 30, 2016 | 10:17 AM
rodz's Avatar
Attachment 1
And it's automatic
Old Aug 30, 2016 | 10:34 AM
Bone stock Civic?
Looks like you blew dash fuse #15.
http://www.tegger.com/hondafaq/tsb/civic/x99-029e.pdf
Install a new fuse and reset the ECU. Then go from there.
Old Aug 30, 2016 | 10:52 AM
rodz's Avatar
Originally Posted by RonJ
Bone stock Civic?
Thanks I'll check the fuse and yeah it's stock just has a y8 intake?
Old Aug 30, 2016 | 12:10 PM
If the fuse is blown, read the TSB.
Old Aug 30, 2016 | 12:13 PM
rodz's Avatar
Will do thank you I'll come back later when I check it and see
Old Aug 30, 2016 | 02:53 PM
rodz's Avatar
Well the fuse is not blown I checked it with a test light and it's not getting power ?
Old Aug 30, 2016 | 03:59 PM
Did you test both fuse tabs with the key in ON(II)?
https://honda-tech.com/forums/honda-...fuses-3079359/
Old Aug 30, 2016 | 04:56 PM
rodz's Avatar
Im Sorry the fuse was not blown
Old Aug 30, 2016 | 05:04 PM
How do you know the fuse was not blown?
Reset the ECU. Do any of the codes return?
Old Sep 6, 2016 | 11:56 AM
rodz's Avatar
Default Hazard plug wires
I just want to know what these wires do I know there to the hazard button but I won't to know what each wire does its from a 96 honda civic
Old Sep 6, 2016 | 12:27 PM
Default Re: Hazard plug wires
Do you have the 96-00 Civic service manual?
If you do some Google searches, you'll locate a download that will have all the info you seek.
Old Sep 6, 2016 | 12:35 PM
rodz's Avatar
OK I will
Old Sep 6, 2016 | 12:38 PM
All work you plan to do should start with the service manual.
Old Sep 9, 2016 | 10:38 PM
Default re: 96 civic d16y7 - Many questions
yes. derpaderp.
Old Sep 10, 2016 | 05:43 AM
rodz's Avatar
Originally Posted by eghatch9295
yes. derpaderp.
Yes they do fit ?
Old Sep 10, 2016 | 07:55 AM
mk378's Avatar
Yes they do fit.
Old Sep 10, 2016 | 08:32 AM
rodz's Avatar
Originally Posted by mk378
Yes they do fit.
OK thank you
Old Sep 20, 2016 | 11:41 AM
Default Re: D16y7 starting problem
Honda-Tech - Announcements in Forum : Honda Civic / Del Sol (1992 - 2000)
Please read the forum Rules sticky.
