2000 honda accord ex trasmission nightmare please help!!
Old Sep 8, 2016 | 08:31 PM
Boostedtegb20's Avatar
Default 2000 honda accord ex trasmission nightmare please help!!
I have a 2000 Honda accord ex. Has f23 in it with an automatic trans
The original trans went bad so I purchased another one from a local junk yard. After putting it in it would slam into gear with a delay. When it shifted into 2ND gear it would just lock up to the point where it would almost throw you threw the windshield so I figured it was bad so from there I took it out and bought one from a Japan dealer and installed that one along with their converter. Now I have the exact same problem!! I've done everything I know to do it reads no codes and the solenoids are good. I even put another ecu and had it flashed to my car and does the same thing. I've been working on these cars for years but this one has me puzzled I'm hoping someone can help me. Thanks mark
Old Sep 9, 2016 | 02:48 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 2000 honda accord ex trasmission nightmare please help!!
How do you mean lockup? Lockup as in the geartrain would lock up the wheels or it would only upshift into 2nd and when you expect it to upshift/lift throttle it just stays in 2nd.
If the TPS is bad it does not always set a code and greatly affects how the transmission shifts.
Check the engine is in proper operating condition as it is what will affect how the transmission works.
Old Sep 9, 2016 | 05:57 PM
Thanks for the reply and when it goes into 2ND gear it locks the front wheels up and just holds itself there. Thanks
Old Sep 11, 2016 | 04:37 PM
Anyone ??
Old Sep 11, 2016 | 05:15 PM
holmesnmanny's Avatar
check for any stored codes
Old Sep 11, 2016 | 05:17 PM
The only code I'm getting is a vtec malfunction
Old Sep 11, 2016 | 05:18 PM
Someone has to of had this problem before
Old Sep 11, 2016 | 05:21 PM
the fact that its doing the same exact thing across two diffrent trannies might indicate the ecu is bad, pull it and open the covers and see if there are any burned spots
Frank Froggatt
May 29, 2018 08:05 PM
Silly rabbit419
Mar 17, 2018 04:56 AM
Chris Mason13
Jun 18, 2017 05:49 PM
mobajwa
Jan 2, 2013 03:29 PM
SilverAccord04
Aug 8, 2010 04:35 AM
