D16Z6: Stock injectors max fuel pressure
Old Sep 7, 2016 | 09:23 AM
band-aid's Avatar
Default D16Z6: Stock injectors max fuel pressure
I have a D16Z6 with modest upgrades: 66mm throttle body, high-flow pump, headers, exhaust. I've installed an adjustable fuel-pressure regulator and I would like to experiment with increased fuel pressure. I'm not looking for serious gains, hence I'm not interested in larger injectors and ECU tuning right now. What I want to know is how much fuel pressure can the stock injectors handle? 50psi? 60?
Old Sep 7, 2016 | 09:50 AM
Former User's Avatar
Default Re: D16Z6: Stock injectors max fuel pressure
What's precisely your goal?
Old Sep 8, 2016 | 05:26 AM
band-aid's Avatar
I'm just trying to force a little more fuel into the engine. The larger throttle body has me running lean. I know that I should just put the stock TB back on so that the engine can work like it's supposed to. But I like to experiment so I would like to see if increased fuel pressure can help the injectors squirt more fuel to keep up with the extra airflow. I've gotten the impression from reading other posts on the subject that it is possible to do so. So I'm wondering can I dial the regulator up to 60psi or will that blow out a seal on the injectors?
Jan 31, 2010 02:46 PM
Eyal 951
Honda Motorcycles
Apr 9, 2007 04:04 PM
Djbower1
Dec 27, 2005 02:56 AM
Leo95SE
Jun 24, 2002 01:03 PM
Malice
Jun 7, 2002 11:31 AM
