ok did my flywheel question get deleted??? well which has timing marks?
Old Nov 8, 2002 | 08:14 AM
BoostedH23a1's Avatar
Default ok did my flywheel question get deleted??? well which has timing marks?
i have a lightweight flywheel and it doenst have the timing mark on it for me to set the timing. what H series flywheels have the stock timing mark on them?
Old Nov 8, 2002 | 08:58 AM
TimeRacer's Avatar
Default Re: ok did my flywheel question get deleted??? well which has timing marks? (BoostedH23a1)
all of them, which is why you're able to take a timing light to them.... If you're talking about aftermarket, none of them. You'll have to put it on yourself.
[Modified by TimeRacer, 9:59 AM 11/8/2002]
Old Nov 8, 2002 | 09:21 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: ok did my flywheel question get deleted??? well which has timing marks? (TimeRacer)
i have a Clutch Master 8lb flywheel, and it has the timing marks on it, i even put a little whit out on the marks so they would be easier to see.
Old Nov 8, 2002 | 09:31 AM
Default Re: ok did my flywheel question get deleted??? well which has timing marks? (Boosted97Lude)
8lbs. damn i dont want that light. break loose like a bitch arealdy.
Old Nov 8, 2002 | 10:07 AM
Boostless97Lude
Guest
Posts: n/a
yep... 8lbs, that to go along with the ~7lbs taken off the crankshaft, and the lighter, but stronger, rods/pistons, and EVERYTHING balanced = almost NO turbo lag
[Modified by Boosted97Lude, 2:08 PM 11/8/2002]
Old Nov 8, 2002 | 11:43 AM
in 2second gear im at full boost (6.5psi) at 3200
Old Nov 8, 2002 | 01:32 PM
4bidden's Avatar
my JUN has timing marks.....~11.24lbs
Old Nov 8, 2002 | 03:59 PM
TimeRacer's Avatar
Default Re: ok did my flywheel question get deleted??? well which has timing marks? (4bidden)
I know the JUN's (at least 2 years ago) cromoly flywheels didn't come with timing marks w/o a machine shop adding them. I had assumed (wrongly on my part) that CM just adonized the Fidanza flywheel and that's it. Fidanza's don't come with timing marks.
Old Nov 8, 2002 | 04:31 PM
im not paying 475 for a jun flywheel thats rediculous
Old Nov 8, 2002 | 07:34 PM
tonydatyga's Avatar
f*ck, my fidanza doesn't have timing marks. why jeebus, why?
Old Nov 9, 2002 | 06:18 AM
Default Re: ok did my flywheel question get deleted??? well which has timing marks? (tonydatyga)
looks like clutchmasters for me then.
Old Nov 9, 2002 | 06:42 AM
Boostless97Lude
Guest
Posts: n/a
i even put a little white out on them just to make it more obvious on my CM
Old Nov 9, 2002 | 06:43 AM
Boostless97Lude
Guest
Posts: n/a
ooops.. i just realized i mentioned that once already, oh well, **** it, you get the point
prelude2.2vtec
Mar 3, 2009 04:31 AM
anomale
Nov 30, 2008 01:34 PM
deucedeuceEK
Jan 2, 2007 08:52 AM
BoostedH23a1
Dec 15, 2003 01:48 PM
BoostedH23a1
Aug 20, 2002 05:31 PM
