96 Honda Accord LX 2.2L F22b2 Crank,No Start
Old Sep 4, 2016 | 02:22 PM
genisis3's Avatar
Default 96 Honda Accord LX 2.2L F22b2 Crank,No Start
Hello Honda guys!!I've short circuited my 96 Honda Accord LX 2.2L manual (F22B2) with the wiring harness from my drivers side door.I tried to turn-on the car and it will crank but won't start.
the fuel pump works,their is compression,but no spark.Replaced the main-relay,distributor and the ECU is good,but still no-spark.I replaced the ignition switch and same no-start issue.
I'm thinking the cam/crank shaft sensor,but scan tool is picking up RPM's.Does any one have any sugjestions what else it could be??Get back to me asap.
Old Sep 4, 2016 | 05:58 PM
theotherchris's Avatar
Default Re: 96 Honda Accord LX 2.2L F22b2 Crank,No Start
Did you check all the fuses?
Old Sep 4, 2016 | 06:32 PM
genisis3's Avatar
I checked all the fuses and put all the right amp fuses where they needed to go.I've been at it for a whole week now at witts end..
Old Sep 5, 2016 | 10:00 AM
genisis3's Avatar
Does any one else have any more suggestions?
Briznick
Aug 20, 2018 12:38 PM
RM022748
Sep 9, 2017 09:43 AM
minigarcia09
Feb 18, 2013 09:42 AM
s9000supratt
Sep 10, 2008 04:42 AM
