91 cluster swap into 88 sedan
Old Sep 4, 2016 | 07:06 AM
1988dxsedan's Avatar
Default 91 cluster swap into 88 sedan
Hey guys. As my name implies, my car is a 88 civic sedan. I did a cluster swap a few years ago from an 88-89 with a tach. Im growing bored and tired of the inaccurate tach. Of course ive been reading, searching, googling etc. Everything I have read says basically you need the cluster hood from a 90-91 do to most cluster swaps in the 88-89 chasis. My question is this: what do you do about the black trim/gauge bezel/vent assemblies piece that is on the 88-89? If I remove mine and use the 90 style cluster hood, it eliminates my dash vents and trim and leaves it unfinished. My assumption is that I need an entire dash swap, but no threads, article's, forums address this so thought i would ask. Ill attatch a pic of the dash piece in question on my 88.
Old Sep 4, 2016 | 07:32 AM
v4lu3s's Avatar
RTFM
Default Re: 91 cluster swap into 88 sedan
so you are putting the cluster from a 90 EX sedan in for example? if so then the parts diagram here indicates that the new cluster bezel has those vents 1990 Honda Civic 4 Door EX KA 5MT instrument panel - HondaPartsNow.com
Old Sep 4, 2016 | 10:41 AM
Didnt specify exactly what model cluster I want to do. Sort of thought all 90-91 clusters were the same. As far as the part your referring to in that diagram: number 47?? It also shows the typical 90-91 hood that is in everyones writups. Are the sedans the only models with that vent trim/hood all in one? My other thought now is will the 90 style part your referring to fit to the 88 dash? Being that the dash is contoured to the bezel trim piece ( item 47).
Black_89
Mar 5, 2013 02:51 PM
88 civic ef
Jun 18, 2008 01:57 AM
zcivicz
Oct 8, 2002 07:01 AM
88 rex
Sep 26, 2002 05:46 AM
AfEn808
Jan 12, 2002 08:34 PM
