Front Tires innerside worn down
Old Sep 3, 2016 | 09:25 AM
greenquark's Avatar
Default Front Tires innerside worn down
Hi there,
I replaced the tires in June. The mechanic replaced the front lower ball joints and the passenger Upper Control Arm and the power steering rack ( it was leaking badly) and the front brakes.
I took my car for a road trip and on the way back I noticed the power steering was pulling to the left. I also noticed that around 60 m/hr the power steering started to vibrate ( Around that speed only)
The driver side tire(inner side) has way more wear than the passenger side tire ( inner side).
I also noticed the front bushing which I replaced , were a bit loose ( there was space between the bushings when I lifted the car.
Is there anything I can do before taking it to a Tire/alignment specialist?
Rear Tires, as good as I got them
Cheers
Old Sep 3, 2016 | 09:55 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: Front Tires innerside worn down
If your steering rack was replaced, you should have had the car aligned then and there.
Old Sep 3, 2016 | 10:07 AM
greenquark's Avatar
Now I know... Live and learn... Should I replace the tires before doing the alignment? Or IT could be done with the same tires?
Old Sep 3, 2016 | 10:12 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
It can be done with the same tires but you will most likely need them replaced depending on how bad they are worn.
MinimusMaximus
Suspension & Brakes
10
Sep 11, 2015 11:28 AM
sambam27
Dec 10, 2003 12:01 PM
MyBigNut
Aug 26, 2002 12:25 PM
Calavera
May 7, 2002 11:46 PM
manveer
Apr 27, 2002 01:37 PM
