Who knows how to fit ITR/GSR airbox in a 96-00 civic?
Old Nov 8, 2002 | 07:59 AM
ryan12321's Avatar
Default Who knows how to fit ITR/GSR airbox in a 96-00 civic?
I've searched honda-tech and other sites as much as I can and I haven't even found one post on it. I know somebody has done it. I've tried it a couple of times already in my 00 si but can't get it to fit. If anybody has descriptions or even pics please help me out. All i want is the box and intake arm on, i'll figure out something for the under tubing since i don't have any of those parts.
thanks.
[Modified by ryan12321, 9:00 AM 11/8/2002]
Old Nov 8, 2002 | 08:01 AM
Archidictus's Avatar
Unceasing Measure
Default Re: Who knows how to fit ITR/GSR airbox in a 96-00 civic? (ryan12321)
don't quote me on this, but I think you need a bigger throttle body. either that or a SkunkII intake manifold to make it couple because the inlet sizes are different. just adapt a piece of PVC pipe to it and use some hose clamps and rubber sleeves until you're satisfied.
why are you doing this anyway? is a regular aftermarket intake not good enough for you?
Old Nov 8, 2002 | 08:08 AM
ryan12321's Avatar
Default Re: Who knows how to fit ITR/GSR airbox in a 96-00 civic? (Archidictus)
A bigger throttle body is not required. I have gotten the intake arm to go on fine, its just there really isn't much room for the big airbox to go or to mount it to anything.
I hate the sound of intakes except for the comptech icebox and i don't have any money to spend. I have a gsr airbox sitting in my basement so its free. And quiet, the most important part to me.
Old Nov 8, 2002 | 09:22 AM
ryan12321's Avatar
ttt, this forum moves too fast.
Old Nov 8, 2002 | 09:42 AM
fowler!'s Avatar
You should be able to fit a GSR/ITR box with an ITR arm in your b series equipped 96-00 civic.
The only thing that you really have to worry about is actually mounting the box. I was trying to mount mine but the screw I had came up a little bit short. There is really only one hole that you can use. Find a longer screw and all should work out fine.
Reading over that...it sounds really really bad
wasanissanFL
Mar 12, 2015 09:35 PM
clem kevin
Feb 11, 2008 03:01 PM
Digga4
Sep 1, 2006 08:57 PM
blykins
Sep 23, 2002 12:33 PM
GsrSdn
Feb 9, 2002 08:59 AM
