98 Civic RPM dropping to 0 and jumping back up (solved)
Friends car is having some issues:
I have a 98 Honda Civic hatchback. The rpm goes from 1000,2000,3000 whatever to 0 out of no where. This only lasts for .5 to 1 seconds before it kicks back up to its original rpm before it went to 0. This problem happens when the car is cold or warm. It can happen in the middle of travel, but most often when I don't give the car a good 2 minutes to "warm up". Usually, when I let it warm up for the 2 minutes after it sitting for the 15 hours at night or 8 hours at work, it will shake and make noises like its dying, the rpm goes back down to 0, and then revives itself and is good as new. The issue is hard to explain, hopefully someone understands what's happening....
Thanks.
Thanks.
So here is what she did.
1. Found the coolant was low so we topped it up and bled it
2. Removed and cleaned the IAC valve, no difference.
3. Replaced entire throttle body including TPS, IAC valve still no difference
4. Changed fuel filter
Any ideas?
Any ideas?
hygienejesus
20
Aug 22, 2016 07:44 AM
