B18CR Swap dies while driving, starts back up though
Old Aug 31, 2016 | 06:41 AM
whited's Avatar
CRX God
Default B18CR Swap dies while driving, starts back up though
My B18CR Crx (Build thread Wrecked CRX Rebuild - Honda-Tech) has a strange issue, and I wanted to get a few thoughts before I jump into fixing it.
I don't drive it all that often, but a few months back it would lose power while driving. I'd push the clutch in, the engine would die. I'd then start it back up, and continue driving no problem, and it wouldn't die again. Now it is getting worst, where I might have to start it back up a couple times before it will stay alive. Once it is going and past the dying stage, it runs fine.
It also seems to be running very rich, but it will still redline at 8.5k or whatever it should.
I am guessing it has to be something with the fuel. Either the fuel pump is misbehaving (I did replace it last year), maybe the temp sensor is mis-reading at a certain temp, or the throttle is mis-reading.
Throw some thoughts out there, I haven't dived into it yet, but just brainstorming before I bring the thunder. I just know it will be a bitch to diagonst since it isn't a constant issue.
Old Aug 31, 2016 | 06:43 PM
~sp33~'s Avatar
EFB055
Default Re: B18CR Swap dies while driving, starts back up though
Certainly sounds fuel related. If it's an aftermarket pump i'd check your connections, although it doesn't explain your overfueling issue.
You're not running Hondata by chance? You could datalog your sensors.
You should be able to hear whether the fuel pump is switching off, especially if it's aftermarket. Either way you could take your rear interior out if it's still there to make it louder. If it is, i'd try substituting in a new Main relay if you're confident the pump is ok and the connections are sweet.
Intermittent is the worst.
Old Sep 2, 2016 | 11:03 AM
fcm's Avatar
fcm
Old Fart
Ditto the above, I would look at the main relay as they are prone to intermittent problems, and common... Main Relay Fix, Troubleshooting (Honda, Acura) and how to solder. 94
Old Sep 2, 2016 | 11:06 AM
testify's Avatar
On vacation
Are your battery terminals tight?
Old Sep 2, 2016 | 11:27 AM
whited's Avatar
CRX God
I replaced the main with a Honda oem one not too long ago.
I do not lose Power as in electricity. I lose power as in the throttle does not respond.
The radio and all electronics continue to work.
I literally can, push in the clutch, let the engine die, let go of the clutch and the engine will run fine again. I do not have to touch the key or anything.
Old Sep 2, 2016 | 11:32 AM
4drEF's Avatar
Keyboard Humorist
Are you get a CEL?
Is the ECU chipped?
Looking for a an O2 code.
Old Sep 5, 2016 | 12:04 AM
~sp33~'s Avatar
EFB055
If you lose power to your fuel pump, the engine will not receive fuel and will cut out. Your accessories will continue to run if it's only an issue with the pump connectors.
Old Sep 6, 2016 | 10:29 AM
whited's Avatar
CRX God
Originally Posted by 4drEF
Are you get a CEL?
Is the ECU chipped?
Always had a CEL, maybe a second CEL I donno.
OB2B not chipped.
02 makes sense, more than anything else right now.
Old Sep 6, 2016 | 03:46 PM
4drEF's Avatar
Keyboard Humorist
Assuming you have the diagnostics port wired up -
I picked up a WIFI OBD2 adapter and an app for my phone for under $25 total.
(They make bluetooth versions as well, but wifi is needed for iPhone.)
https://www.amazon.com/s/?ie=UTF8&keywords=car+wifi+obd+2&tag=googhydr-20&index=aps&hvadid=105357827659&hvpos=1t1&hvnetw= g&hvrand=7387146463944997045&hvpone=&hvptwo=&hvqmt =b&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9031154&hv targid=kwd-210222266644&ref=pd_sl_1bq1v8v7ij_b
Old Sep 7, 2016 | 01:29 PM
fcm's Avatar
fcm
Old Fart
If the PGM-FI Main Relay is new, I would also suspect the fuel pump or connections to it, the fuel pump is also prone to intermittent problems. 94
markz95.4dr
31
Jan 15, 2012 12:58 PM
Bones82
Honda Civic (2001 - 2005)
Oct 14, 2010 07:15 PM
geonracer
Jan 24, 2010 09:22 PM
JDM94HATCH
33
Jan 15, 2007 11:07 PM
psychotic_z
Sep 20, 2004 06:21 PM
