VSA Light On in 07' Si. Brake switch the issue?
My VSA light has been on for about the last 6 months and i'm finally getting around to fixing it. I've read that it may be the Brake switch below the brake peddle, and its a relatively easy fix. Has anyone else had this issue and fixed it? Thanks ahead of time for the input.
The issue can be due to other things. It would be best to get the trouble code(s) read with a OBD II scanner/reader that is capable of reading Honda ABS/VSA trouble codes to help narrow what may be the issue.
If the car has TPMS and a TPMS indicator light is also on, it can even be due to a dead or dying TPMS battery.
VSA light is as vague as a check engine light. Mine has come on once for a really bad misfire and another time for a wheel speed sensor.
Gotta get it scanned like the other dude said.
jxhxb
27
Nov 25, 2007 10:25 AM
go2sleep
Jul 31, 2006 09:18 PM
