1000awhp CRX AWD Turbo 4G63T
Old Aug 30, 2016 | 06:13 PM
Rob Simon's Avatar
Default 1000awhp CRX AWD Turbo 4G63T
in the next few mouths i will be building a super car. i will be using a 90 CRX SI unibody and a DSM 4G63T Engine and a AWD automatic
W4A33 Transmission with DSM/EVO 3 rear diff. all the suspension is custom made and tubular front end.
the Drive shaft tunnel will be welded in from a 90 Civic wagon and custom drive shafts, Axles and wheel hubs from Drive Shaft Shop.
ill post the parts list to show you the miss I'm in lol
Old Aug 31, 2016 | 06:45 AM
whited's Avatar
CRX God
Default Re: 1000awhp CRX AWD Turbo 4G63T
Do not download the docx. It may have a virus.
Old Aug 31, 2016 | 08:01 AM
4drEF's Avatar
Keyboard Humorist
Oh man... now I really want to download it just to find out!
Old Aug 31, 2016 | 09:26 AM
Former User's Avatar
Removed. OP, post a pdf.
Old Aug 31, 2016 | 02:01 PM
Rob Simon's Avatar
actual car I'm using for the project
Boostin demon short block with magnus crank
And ½ head studs with head gasket and grile 6125.00
Boostin stage3 head 2029.00
Core block $1,952.26
Core head $1,211.03
Front Line Fab oil pump 1200.00
-16AN Magnus water neck non fill cap
Kelford cams 294/300 600.00
UNORTHODOX RACING "ULTRA T" Cam gears 380.00
Gates blue Timing belt 200.00
GSC 0 tick lifters 180.00 for 16
OEM rockers 25.00 ea
oil pan moroso 580.00
OEM oil pick up tube 24.00
Mitsu moto 68C thermostat
Kiggly 12 point crank sensor 150.00
OEM cam sensor 85.00
2g timing plate solid motor mount
unorthodox pulleys
DSM OEM 2g steer pump and AN fittings
super 99 FP turbo
ATI crank pulley damper
arp cam tower bolts 70.00
arp ss intake ex studs
fel pro master
magnus intake gasket
magnus V3 intake manifold dual rails 75mm TB 999.00
magnus dual fuel rails polished
fic 8 1800cc injectors 565.00 for 4
75mm Wilson throttle body
pro street t4 manifold
rear main seal housing 25.00
arp cam bolts 18.00 pear
6 arp crank bolt
OEM rear crank seal housing bolts 2.00 ea
2g Dip stick
Front Line Fab Dip stick handle
2g Dip stick tube
Oil pan bolts
Front Line Fab Valve cover 650.00
Valve cover bolts.
Front case bolts.
Oil cyl oilers 136.09
$24,000.00
tmz 2g dsm transmission a/t build 6600.00
2g a/t core 450.00
sin speed 2g 6000rpm stall 8” torque conv. Build 900.00
2g TC Core 100.00
tmz 2g transfer case a/t build 1800.00
2g t-case core 150.00
tmz 2g rear diff build 2320.00
2g diff core 264.00
$12,584.00
front sub frame $2500.00
4 front arms up/low $1000.00
rear sub frame $1500.00
2 rear up control arms $250
2 rear low control arms F7 88 500.00
2 rear trailing arm and knuckle $1000.00
2 front knuckle $500.00
4 2g DSM GSX hubs $120.00ea
2 front kit DSM 2G GSX big brakes f/r 3600.00
8 front arm rod ends
4 front arm ball joints
2 rack ball joints
2 rear trailing arm rod ends
4 rear up control arm rod ends
BC CRX 88 Coil Overs 2800.00
DSS Axles 6000.00
DSS Drive shafts 2000.00
Tub front end and lite front inner fenders $3000.00
$25,130.00
Custom made mil spec chasses harness. 4000.00
MOTEC M190 $5,700.00
MOTEC C1812 12" COLOR DISPLAY LOGGER W/USB
MOTEC D153 3.5" COLOR DISPLAY $2,220.00
MOTEC 3 Malti trim dial 165.00ea
Milspec engine harness in and out 3000.00
Mil spec transmission wiring harness 1000.00
MOTEC 15 POSITION CAN KEYPAD $589.00
MOTEC PDM32 $4,890.00
Spark tech Coil on plug and with M&W Pro-14 CDI SEQUENTIAL box. black coil holder 1460.44
$27,366.00
Hid 10000k high and low head lights fog lights $300.00
Blue led hood lights window sprayers $6.00
Led tail lights 30.00
Led marker lights 30.00
Under car light kit xk glow led $504.00 for kit
BT LED RGB Controller XK Glow $98.00 ea 300 for 3 T
Led roll milti color 50.00 for 2 rolls 16feet ea
Strobes 80.00 for 4 in kit
Hid fog lights 3” halo $80.00
Side markers type r $55.00
E3iO Car pc full loaded, 3000.00
ASUS blu-ray player 200.00
Wd wi fi ssd 3tb WDBSMT0030BBK $250.00ea 500 FOR 2 T
I pad mini 4 600.00
I pad pro 900.00
Alpine PXA_H800 1000.00
Alpine RUX-C800 400.00
Two ground zero 15spl extreme 1ouhm x2 4.24 3ft 2000.00 ea 4000for pair
HCCA 20000.1D amp 5000.00
HCCA 3000.4H amp for the 8” subwoofers $1,199.99
XTR 1200.4 amp $469.99
XTR 600.2 amp $279.99
2 morel ELATE TI 903 ELATE TITANIUM 3 way COMPONENTS $3500.00pair 7000,00 for 2 pair
morel 3 way ELATE TI 503 $2000.00
4 morel ULTIMO TI 802 8” subwoofers 2 ohm in the door panels and rear side deck. $879.00ea $3516.00 for 4 T
4 CH home made stereo to mono/stereo converter for 4 CH bass amp and 8” subwoofers. $400.00
2 XS Power XS30K batteries $3000.00ea 9000 for 3 T
Showtime STCA 2/0 00 AWG Gauge blue power cable 115.00 of 50’
Showtime 4 AWG blue power cable $75.00 for 100ft
Sky high audio speaker 14 gauge wire for components $120 for 400’
sky high audio speaker 12 gauge wire for 8s $140.00 300’
shy high audio 8 gauge sub wire for 15s $95.00 for 50’
2 tool maker 1/0 to 2/0 amp input $29.00ea
6 Tool maker 1/0 to dual 2/0 amp input $40.00ea
Tool Maker buzz bars two batts 8 2/0 gauge holes 2 4 AWG holes 1 8/4 AWG hole. $200.00
Sky high audio 2/0 ring connecters or grounding blocks 50.00
Sky high audio 4 gauge ring connecters 30.00
8 2/0 shy high audio ANL fuse holder 60.00 ea
JDM EF8 heated power mirrors $200.00 for pair
Power door locks $50.00
Electric Life custom fit power window kit HD31-K $252.00
Spal power window switches Part # 33040147 $72.00
viper alarm 2way color remote and GPS smart start. $1000.00
sparco kill switch, $55.00
19 led blue toggle switches with blue safety covers, 150.00 for 19
4 blue single led for high beam and starter panel, 50.00 for 4
2 green single led for turning signals, $28.00 for 2
blue starter button. $20.00ea
1 Auto meter sending units 240-33 OHMS. $85.00
$44,297.00
Honda CRX Cyber PRO 2 Full body Kit HAVE it
F1 fenders Item #896227 $114.00 pair
Bodykit.com headlights and clear corners could have it
bumper lights hard to find
cyber tail lights center and tinted stock lights
Fiber glass hood Franks Custom Fiberglass, $300.00
Duraflex Spyder Hood Scoop dual ram air $150.00
Super Style 26in Light Spoiler $505.00
Carbon fiber hatch TL8891HDCRX seibon $697.00
$1,766.00
auto meter phantom +45psi Boost/Vacuum, $72.00
ten color white face glow shift gauges;
2200 F Pyrometer EGT Gauge, $117.00
2 Fuel Level Gauge 240-33 OHMS 0-90 OHMS $65.00
3 pod A pillar $100.00
$354.00
chrome dub rio 5 18”x 8” rims $242.00ea $968.00 a set of 4 T
nitto high performance, all-season NeoGen HP 215/35R18 $400.00ea $1600.00 for set of 4 T
$2,568.00
Stock Honda parts;
brake and gas petal assembly for auto trans, $500
Door panels for EF8 with power windows option, $200
Ef8 power windows inner door levers, $200
EF8 EDM power window switch pods, $200
94-95 Integra center console, $100
$1200.00
Neo cobalt color 75mm intercooler piping 2mm aluminum wall
Megan or KP 1200HP Air to Air Intercooler 280.00 or 500.00
4” neo cobalt color intake pipe 2mm wall aluminum. $30.00
6 Black intercooler pipe couplers 3” x 3” $12.00ea 72.00 for 6
1 turbo coupler $32.00
K&N air filter $90.00
88-’91 Civic/CRX Alpha Series Half Radiator 349-05-1550 welded
-16 AN in/out lets. $200.00
Weapon R Coolant Tank bottom inlet $100.00
Remote 55 GPM coolant pump $400.00
Neukin Race Oil Catch Can v2 $300.00
2 12” puller Part # 30103202 $238.00ea and
1 10” puller Part # 30100360 $92.00 and
1 10”pusher Part # 30100320 $86.00 Spal fan
B&M trans and engine oil coolers with fans $300.00 ea $600.00 for 2 T
Polished Tial Q Blow Off Valve 50mm $295.00
Fuel cell 17gal meth RCI $200.00
custom12 gal 91oct. fuel cell, $150.00
1 Fuelab 1000hp in tank pump, $520.00
42402 Prodigy Fuel Pump High Power EFI In-Line, $850.00
2 magnus fuel rags $180.00ea
2 magnus fuel filters. $80.00ea
$5,020.00
30’ of -12 AN feed fuel hose,
30’ of -6 AN return fuel hose,
4’ of 16 AN coolant hose,
-4 AN of turbo oil feed,
-10 AN of return turbo oil,
-8 AN turbo coolant hose,
-12 AN trans oil coolant hose,
-12 AN engine oil coolant hose,
-4 AN B.O.V. hose,
-4 AN waste gate hose,
8 -10 ORB to -12 AN fittings,
2 -6 ORB to -10 ORB fitting,
6 -12 AN straight hose ends,
2 -12 AN 90* hose ends,
2 -6 AN 90* hose ends,
4 -12 AN to ½ NPT, coolers
3 -4 AN to m10x1.0
XX to -12AN fitting outlet and inlet on filter housing
$1600.00
Two HKS Universal Stainless Hi-Power Ti Mufflers 75mm inlet 170mm body 120mm tip , $325.00 ea $650.00 for 2 T
viberant 3" Catalytic Converter, $490.00ea
204 ss exhaust pipe 3”, 600
60mm v60 tial waste gate polished $400.00
**mm pipe for WG, $100
WG rerouted back into exhaust pipe
Dsm 2g a/c comp 261.00
Universal heat xctanger $700.00
universal a/c hose fittings and dryer 100.00
brake master 155.00
$3,456.00
Dsm GSX 2g knock sensor
100psi map sensor
oil temp sensor
oil press sensor
2 water temp sensor
intake manifold air temp sensor
$151,909.00 USD
$19,748.17 tax
$171,657.17 USD with tax
$220,150.32 CAD with tax
$2,750.00 CAD for 90 CRX with cyber pro 2 body kit
$2,500.00 CAD for civic wagon and GSR turbo engine and CRV AWD trans. [IMG]file://localhost/Users/macbook/Library/Caches/TemporaryItems/msoclip/0/clip_image002.png[/IMG][IMG]file://localhost/Users/macbook/Library/Caches/TemporaryItems/msoclip/0/clip_image004.png[/IMG]
Old Aug 31, 2016 | 02:11 PM
whited's Avatar
CRX God
$150k on a CRX????!!!
Last edited by TheShodan; Sep 4, 2016 at 02:14 PM. Reason: allowing user to maintain his point but shorten length.
Old Aug 31, 2016 | 02:22 PM
End the spamming. You made your point.
Old Aug 31, 2016 | 02:48 PM
Rob Simon's Avatar
Thats the price to go fast and loud. in a car it ant the cost of the car to cost of parts. its how you use them.
sure i could use a $85000.00 GTR with 100000.00$ cost of parts. but I'm going to beat that GTR With the CRX on the circuit,
and drive the CRX home.
Old Aug 31, 2016 | 02:59 PM
v4lu3s's Avatar
RTFM
so did this happen yet or is this just a pipe dream? the car is NOT my style and the parts list is not my thing either but i respect good work and good execution.
Old Aug 31, 2016 | 03:49 PM
Rob Simon's Avatar
it will happen soon
Old Aug 31, 2016 | 04:18 PM
What's your timeline?
Old Aug 31, 2016 | 04:44 PM
pogeeboy27's Avatar
Cool build, but what is your goal with this car? Show? Race? If race, what racing were you planning on doing?
Old Aug 31, 2016 | 05:32 PM
Rob Simon's Avatar
my timeline is starting in a few months i have to wait for my money to came in that i sued a guy for my last car and pain and suffering .
the body will be striped down and then framing will start. 18 hours with stripe and tubular subframes and semi tub front end and susp. knocks installed and tiged.
with the drive shaft tunnel welded in too. 12 hours for the engine and transmission and rear diff with rad and intercooler with piping installed
3hours to install the wiring and motec stuff. and i don't know about the stereo yet ill be subbing that job off. swell as painting it.
Old Aug 31, 2016 | 05:35 PM
Rob Simon's Avatar
my goal is for show and street with fun on the circuit track when its opened to public
Old Aug 31, 2016 | 06:18 PM
whited's Avatar
CRX God
Please see a financial advisor, about money management if you are seriously considering this.
I'm pretty sure a 50k budget would get you a very enjoyable car.
Know this cause it is 100% true. Dropping 150k into a crx, will leave you with a car that you could probably sell for 20k someday. Every part you order will be worth 30% of what you paid for it as soon as you open the box.
Old Sep 1, 2016 | 04:54 AM
Schister66's Avatar
Man U FTW
For this kind of money, i'd buy an Audi RS7 and have enough left over to build a turbo K series
Old Sep 1, 2016 | 06:18 AM
Dark_Teg's Avatar
100% BS
4 electric fans, ac, and a ginormous turbo and manifold under the hood of a CRX.
The over detail screams Wantboost.
Old Sep 1, 2016 | 10:43 AM
4drEF's Avatar
Keyboard Humorist
Why not just EVO X?
Then you save a boatload of money, can still drive home after track days, have a superior suspension on the track, have a much nicer car inside and out, and more than likely a better resale value because it's an instant classic even though it's brand new.
Old Sep 1, 2016 | 11:15 AM
Geis's Avatar
Can we all just ignore this until some legitimate proof of progress begins?
Old Sep 1, 2016 | 02:53 PM
rudebwoy's Avatar
Is this a dream or reality? Where is the bomboclaat engine pictures? No one give 2 ***** about no raassclaat riced out body kit car. a wha di bloodclaat?
Old Sep 1, 2016 | 04:03 PM
Rob Simon's Avatar
i realized theres too meany fans but on a DSM GSX you can't make it work with four fans
two on the intercooler and two on the full size a/c and rad
i going to try my hards to make the A/C work.
Old Sep 1, 2016 | 04:13 PM
Geis's Avatar
'too meany', huh?
Old Sep 1, 2016 | 04:43 PM
slomofo's Avatar
GDD Member
This sounds like one of two things:
1. The 16 year old teener dreamer who is compiling a list of random **** that he thinks he'll one day accomplish, but never will. List complete with off the wall pricing ($3200 for a CORE 4G63? LOL).
2. A terrible troll.
Old Sep 1, 2016 | 06:02 PM
Geis's Avatar
Yeah pretty much man, surprised Ronj let this one stay alive.
Rob Simon's Avatar
the brand new block core is 2000$ CND with the stock rotating assembly its cheaper then the block it self if you where going to buy the block it self brand new
