1992 Honda Accord won't start
If it turns over but won't actually start, I believe the main relay or distributor may be bad. Make sure you can hear the fuel pump humming when you turn the cars electronic system on with the key.
bad coil is the usual suspect if no spark.
Advanced Ignition Troubleshooting - Team Integra Forums - Team Integra
Starting Problems
Starting Problems
Runeknight95
Sep 18, 2013 03:15 PM
