diagnosing my power door lock problem
Old Aug 28, 2016 | 09:17 AM
Oxadiba's Avatar
Default diagnosing my power door lock problem
Hello everyone,
My car has an aftermarket alarm/keyless entry system installed by previous owner (96 ek civic audm)
Car locks and unlocks fine with the key, but with the keyless button, the driver side will attempt to move (seems like the rod can't generate enough force) but the passenger side wont move at all. Car doors are closed.
Also when i'm inside the car and move the lock manually, the driver side locks, but the passenger side only locks 50% of the time.
Just wanted to make sure I'm correct in assuming the actuators are screwed before i spend money changing it,
Thank you
Old Aug 28, 2016 | 03:23 PM
fcm's Avatar
fcm
Old Fart
Default Re: diagnosing my power door lock problem
If the power locks are stock, the problem is most likely the switches, [for central locking] inside the actuators that are the problem, so the actuators need to be replaced.
When you say, "Also when i'm inside the car and move the lock manually" do you mean with the door lock switch or the door lock manual lever???
If you mean the door lock switch, my guess is the Power Door Lock Control Unit is the problem. 94
Old Aug 29, 2016 | 01:03 AM
Oxadiba's Avatar
Inside via the lever
Looks like ill be chsnging the actuator, thanks for the reply
Old Aug 29, 2016 | 08:16 AM
chrysler kid's Avatar
Things to try
Silicon spray on the lock assembly on the outside of the assembly. My passengers side on the red hx was not locking or unlocking and i saturated the lock with wd40 and it's functional again
If replacing the actuator does not cure the problem test the power wire to the lock control module for 12 volts. It should be a white wire to a red stripe to a box hanging on the drivers door. Sometimes the wiring In the door harness can break and disrupt signals
Black Diamond
Jul 21, 2010 03:26 PM
Nismo3112
May 29, 2009 05:19 AM
jimmy o.
Nov 27, 2008 01:14 AM
birds4us
Honda Civic (2001 - 2005)
Aug 31, 2008 10:17 PM
splitime
Nov 1, 2002 01:02 PM
