Ej1 has 4x114.3 rear studs please help
Old Aug 25, 2016 | 05:29 PM
joshEj1's Avatar
Default Ej1 has 4x114.3 rear studs please help
I had purchased a ej1 with a rear disc swap already done and I'm going to change the pads and rotors yesterday to realize that the rear isn't a 4x100 but a 4x114.3, I was confused due to the fact that It does has rear integra calipers but different hub I'm assuming? I can't tell what size rotor I need now and I been trying to look everywhere for a rotor or at least closest match to the 239mm rear rotor the integra calipers need but in 114.3. This is the first I've ever seen someone do this and I've gone hours online trying to see if anyone has done this so I could find a answer but no luck. Any help is greatly appreciated from how to figure out what rotor I need to recommendations on what to do.
Side note: I know I can redrill but I'm tight on cash now for me to take it to a shop and the rotors it has now aren't redrilled so there must be a rotor I can use?
Old Aug 26, 2016 | 08:53 AM
Swift's Avatar
Default Re: Ej1 has 4x114.3 rear studs please help
if it is 4x114.3 my first guess is the 1996 integra type r
Old Aug 26, 2016 | 02:22 PM
slomofo's Avatar
GDD Member
Not positive, but I think 90-93 Accord rear rotors will fit.
Old Aug 26, 2016 | 02:40 PM
joshEj1's Avatar
Well the oem size for integra rears are the 239mm diameter and 48.2 overall height.
So I been looking at alternatives but first I'm not sure if it's possible or just plain dumb but if someone could tell me a definite answer to this I'd appreciate it. Can I use different size rotors or will it totally affect the braking or just not fit etc.
There's the 98 4cyl Accord sedan with 259.8 diameter and 48.2 overall height
I'm still looking for more options but so far that's as close to spec as I've found so far
Old Aug 26, 2016 | 02:42 PM
slomofo's Avatar
GDD Member
If you get a bigger rotor, how do you expect your caliper bracket to go back on?
If you get a smaller rotor, what do you think your pads will look like in 5k miles?
Old Aug 26, 2016 | 02:47 PM
joshEj1's Avatar
Yeah I figured I can't go anything but oem size. I'm just thinking desperately here due to it being my daily and not wanting to ride on a worn down rotor. I was thinking best bet is to measure the current rotor and look up the specs and see if I get a hit, any other possible suggestions you could possibly give? Thank you by the way.
Old Aug 26, 2016 | 02:56 PM
slomofo's Avatar
GDD Member
I just checked....
USDM ITR 5x114.3 Rear rotors are
Outside Diameter (mm): 259.08
Overall Height from Center (mm): 47.75
Nominal (New) Brake Surface Thickness (mm): 9
The 90-93 Accord has
Outside Diameter (mm): 259.59
Overall Height from Center (mm): 48.51
Nominal (New) Brake Surface Thickness (mm): 10
98 Accord:
If the JDM and USDM ITR rotors have the same specs, then it would appear that you were correct with the 98 Accord.
SOHC_me
Oct 9, 2006 01:51 AM
freakin
Jul 1, 2006 08:59 AM
Liquidgsr
Jun 10, 2005 09:35 AM
LilBoi
May 2, 2004 07:32 PM
IS3Fifty
Mar 5, 2003 06:46 AM
