Suspension & Brakes Theory, alignment, spring rates....
Please help me determine the best course forward with my wheels and brakes
Old Aug 23, 2016 | 09:18 PM
hondur's Avatar
Dur Da Dur
5 Year Member
Default Please help me determine the best course forward with my wheels and brakes
I bought some 15" GM steel wheels, hoping they would clear my new integra type r brake calipers. They do not, I had to put my lug nuts on before the wheel in order for it to clear the caliper. The offset is that terrible on these pieces of ****. But, I would prefer steel wheels.
I can either buy Si (or whatever) wheels and some high end locking lug nuts, or press the hub off the spindle, hammer the old studs out, install ARP extended wheel studs, Timkin bearings and a huge (aprox. 2 centimeter) wheel spacer, or buy a pair of those two inch wheel spacers that have another set of wheel studs built into them. I like the steel wheels better, no one would steal them unlike Si wheels. They're cheaper to replace, easier to find, etc. But, I'm not about to double the budget for this to keep steel wheels.
What do you guys think?
Old Aug 23, 2016 | 11:06 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: Please help me determine the best course forward with my wheels and brakes
01+ civic steel wheels are 15" iirc.
Old Aug 24, 2016 | 10:10 AM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Troll post. You're an idiot.
eH.
Old Aug 24, 2016 | 12:35 PM
hondur's Avatar
Dur Da Dur
5 Year Member
Dorman sure makes an OEM equivalent 15" steel wheel, but it may still have the clearance issue that my current 15" GM wheels have. I guess my best bet would be taking my spindle/caliper back off and bringing it with me to the junkyard like I should have the first time. The GM wheels will still be good for the rear of my vehicle, hopefully caoboy is rite and those honda wheels will clear the caliper. If not, I guess i'll try and find some webs or Si's fit for a poor person.
Old Aug 24, 2016 | 02:31 PM
98civdx's Avatar
Master Detailer
How big of a spacer do you need for them to clear?
Old Aug 24, 2016 | 04:47 PM
hondur's Avatar
Dur Da Dur
5 Year Member
At least an inch. Someone from d-series linked me to the good brake upgrade thread on Team Integra. I was stuck using an awful version of the resource that I found on honda-tech and that honda-tech version pales in comparison. The 15" steel honda wheels apparently do fit, so I don't need to even test fit the dorman oem-equivalent I ordered from the parts store. I was sitting here thinking that I'd need to tape rags to the caliper and wrap tape around the wheel studs and the mating surface of the wheel to make sure they don't give me a hard time saying "oh you installed this wheel you can't return it" and I don't even need to. Too bad I didn't find the team integra thread in the first place, now i've tied up almost a hundred dollars worth of credit for about a week.
Now I just need to finish cutting the anti sway bar linkages off my 24mm bar, slap it in, finish wiring my interior gauges and security system, put my dash back in and start up the z6 I spent too long rebuilding for the first time.
Old Aug 26, 2016 | 07:22 AM
spAdam's Avatar
Loved
Community Favorite
The '01 Civic steel wheels fit fine over the itr calipers, I ran them for years with that setup.
iHEARTMYCiViC
May 6, 2012 11:29 AM
Shakey021
Welding / Fabrication
Jan 7, 2010 05:03 PM
ekcivic9
Oct 14, 2005 10:49 PM
dunkd
Jul 19, 2005 01:51 PM
1 2 NV
Jan 24, 2003 04:49 PM
