Bogarts full set 4x100, rsx mishimoto shroud, k series shift cables, K tuned no cut++
Old Aug 23, 2016 | 12:56 PM
bretx0r's Avatar
Default Bogarts full set 4x100, rsx mishimoto shroud, k series shift cables, K tuned no cut++
All prices are picked up in Sacramento, CA area. PM Me if interested.
Attachment 431558
Bogart Fly Star wheels ~4.5 backspacing fronts ~1.75 rears. Identical damage on both front inside barrels from previous owner mounting on a car with calipers that were too large, doesn't affect balance. Needs 9.5 brakes only unless with ~10mm spacer (not included). Required shank lug nuts are included! Rubber valve stem front, metal rear. Ran smooth no problems. Damage on face of one of the fronts pictured. Polish is about a 6/10 $800
Attachment 515092
Attachment 515093
Attachment 515094
Attachment 515095
Attachment 515096
Attachment 515097
K tuned no cut shift box. Complete with necessary hardware. Threads backed out where the gear selection lever pivots at the longer travel setting and may need to be chased, works fine otherwise. $200
Attachment 515099
K tuned OEM Spec shift cables. One cable is a new replacement from factory due to the previous cable breaking. The other was used along with an OEM cable for less than 5k miles and the bellows began to crack and separate at the transmission side. Comes with K-tuned solid bushings. $150
Attachment 515100
Attachment 515101
Attachment 515102
BNIB Mishimoto RSX dual fan shroud. Ended up not working for my application, didn't remove from sealed oem bag. $150
Attachment 515103
Attachment 515104
02 RSX seats black. Drivers seat is pretty rough, tear at lower seam, middle of rear lower, bolster wear, height adjustment dial is rough to turn. Passenger seat is in good condition with minimal bolster wear, small tear in the back at the zipper. Both buckles, airbags and airbag computer included, Type S Bose amplifier is NOT included. $150 for pair, wont separate pick up only on this item.
Attachment 515106
Attachment 515107
Attachment 515108
Attachment 515109
OEM DC5 upper and lower manifolds heatshield included, got this with an old swap, came from HMO. Stud on upper is stripped, got it that way. Never needed, good upgrade over stock for USDM. O2 sensors are NOT included. $150
Attachment 515110
http://imgur.com/a/4FUdC <-----ALBUM FOR IMAGES. Don't click it just copy and paste IDK what is with H-T forum code but it sucks and I'm not creating a photobucket account to host images
Old Oct 29, 2016 | 12:51 PM
bretx0r's Avatar
Default Re: Bogarts full set 4x100, rsx mishimoto shroud, k series shift cables, K tuned no c
fghdfghfgh
ludatic98
Jun 30, 2010 08:10 AM
ATS*PEE
Northern California (Sales)
Nov 7, 2008 08:23 PM
gsr-2nr
Aug 11, 2007 01:49 PM
jdm_Integra0369
Jun 8, 2006 10:24 AM
