Brakes
Hey guys.. Just a quick question for someone... I recently noticed my brakes were leaking. I thought it may have been the hose but, it was leaking around the banjo bolt. I was told to replace the washers and that should fix that problem. So I bought the washers and was told they go on a certain way...I seen that one side is flat and the other is rounded.. Whichside goes which way?
Never seen ones like that, but I would guess that the flat part faces the banjo and the rounded part faces away so they, [rounded part] crushes as you tighten the bolt, taping with brass hammer on the bolt as you tighten it will help crush thwe washers properly, the operative word here is tapping, not hammering. 94
slacks
10
Mar 3, 2008 08:51 PM
SuperMan19
Mar 6, 2003 01:17 PM
