97 ex auto - cleaned throttle body and now car wont start
Old Aug 23, 2016 | 04:50 AM
GPC91's Avatar
Default 97 ex auto - cleaned throttle body and now car wont start
ok i have a 1997 ex automatic so the iacv is under the throttle body. i took everything apart and cleaned well. the actual iac sensor wouldnt come off so i tried not to spray in that hole. the map does not have a gasket which i found strange and figured might have been the idle problem to begin with and i had to reuse the gasket on the iacv and the throttle body gasket. im wondering if these could cause me not to start by letting more air in or whatnot and if i could use regular gasket maker sealer for it instead napa said i cant get just the gaskets and i need to get the part with it and they want 204 for just the iacv which is crazy high. it just cranks and cranks. i let sit apart for over a day to dry all solvents. i checked all my connectors and they are in place. i have heard map and iacv are the same but on the automatic they dont seem to be able to reach to interchange so im 99% sure they are right. any help on things to check would be appreciated. this is my girls car and she leaves for college in 4 days... i was trying to help her idle not kill it.... she is pissed and i am in the dog house for this one..
Old Aug 23, 2016 | 09:31 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default re: 97 ex auto - cleaned throttle body and now car wont start
Go to the Honda Dealer for the gaskets.
Old Aug 23, 2016 | 12:49 PM
GPC91's Avatar
i took the map gasket off of another civic i have around. same size. and the iacv one wasnt to bad looking. would those gaskets really cause it not to even start?
Old Aug 23, 2016 | 02:05 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I would check to see if you can pull any CEL codes. I suspect since it won't start, there should be some populating after 30 seconds or so of cranking the motor.
Old Aug 23, 2016 | 02:15 PM
tony_2018's Avatar
Fish Twig
Map sensor has a small o-ring. IACV has a rubber gasket. Did you mistakenly mix up the map and tps sensor?
Old Aug 24, 2016 | 02:35 AM
4Xreincarnated's Avatar
Default Re: 97 ex auto - cleaned throttle body and now car wont start
start with this OP
egsleepercivic
May 9, 2015 11:21 AM
Project97EX
Dec 18, 2012 03:18 AM
patrick4588
Engine Management and Tuning
Aug 9, 2008 05:20 PM
chiefb26
22
Apr 18, 2008 05:32 PM
PowderB16
Jul 16, 2004 08:34 PM
