Looking to sell my track car/project.
located in southern Wisconsin, 45min south of Milwaukee.
Can be reached by text at 262-325-4157$6,000 obo
1992 civic si
unknown miles on body, body is clean for its age, but not mint.
Engine:
Jdm b18c/itr swap, roughly 50,xxx on it
head gasket last summer, arp head studs, oem timing belt
skunk2 alpha header
custom intake to integra air box
t1r catback exhaust
exedy stage 1 clutch with 50 miles on it
new clutch master and new clutch slave
act light weight flywheel
hasport mounts
hasport chromoly axles
interior/exterior:
Kirk racing roll bar
saebelt 4pt harness
sparco evo 2 US
PCI seat bracket
mugen steering wheel
works bell steering wheel hub
rear is gutted, no speakers/head unit.
oil psi gauge/water temp gauge
crank windows
moon roof was removed, roof cap in place for weight
wings west front lip
half cut rear bumper due to damage on lower section
Suspension/wheels:
bronze 15x8 +36 traklite gear rims/225-45-15 hankook ventus rs3
PIC select coilovers, 14k/12k
function 7 lca's
asr rear subframe bar/sway bar
function 7 rear sway bar end links
moog front lower ball joints
moog front outer tie rods
BWR rear camber kit
BWR rear toe arms
hardrace front upper control arms
ARP extended wheels studs front/rear
energy suspension bushings throughout the entire car
new oem RTA bushings
Brakes:
ITR front calipers
Mini cooper blank rotors
hawk pads
15/16" master cylinder
steel braided lines front/rear
Bump for a well built car and plenty of my time invested in it, I know the bones of this car in and out and no corners were cut and performs extremely well
