KS 98 HONDA CIVIC LS-VTEC (WICHITA KS)
Asking Price: 5000
Email Address/Phone Number (optional): 316-5 ONE 8-336 ONE TEXT ONLY
Item Description: A CAR THAT FOR SALE
Pics: SCROLL DOWN
Year: 1998
Make: HONDA
Model: CIVIC
Mileage: 167,000
Title Status: CLEAN AND CLEAR
Transmission: LS 5 SPEED MANUAL NO GRIND OR POP OUT
Drivetrain: B18B1 BLOCK WITH B18C1 HEAD
CHASSIS-
1998 CIVIC HX - 99-00 FRONT END, REAR BUMPER, AND TAIL LIGHTS - SHAVE SIDE MOLDINGS - REAR CIVIC DOOR HANDLES - MID WING SPOILER
TRI COAT PAINT JOB. BRIGHT WHITE BASE WITH BLUE PEARL
INTERIOR -
SI FRONT AND REAR SEATS + STEERING WHEEL.
DUAL GAUGE CLUSTER FILLED WITH BOOST PRESSURE GAUGE
AND A AEM WIDEBAND GAUGE
SUSPENSION AND WHEELS -
FORM & FUNCTION TYPE 1 FULL BODIES COIL OVERS
DRAG DR-20 15 X 7.5 X +10 OFFSET
195/50/15 FALKEN TIRES. ABOUT 60% THREAD LIFE
ALL FENDERS ARE ROLLED AND ONLY NATURAL CAMBER ONLY
ENGINE -
B18B1 BLOCK - STATIC BALANCE - RE POLISH CRANK - OEM P73 PISTON ON PR-4 RODS WITH
ARP ROD BOLTS RODS WERE RECONDITION - ACL ORIGINAL MAIN BEARINGS
ACL HX RACE ROD BEARINGS - NEW 99 GSR OIL PUMP AND PISTON RINGS-
ARP HEAD STUDS
B18C1 HEAD - DUAL SUPERTECH (95LB SHIMMED AT 0.500) VALVE SPRINGS AND TITANIUM RETAINER - JUN TYPE 3 CAMS AND AEM TRU CAM GEARS -
VALVE JOB AND RESURFACED NOT MILL - DC HEADERS - T1 OIL CATCH CAN
DRIVETRAIN -
LS NON LSD TRANSMISSION NO GRIND OR POP OUT - EXEDY STREET CLUTCH WITH A 11 LB FLYWHEEL -
ELECTRONICS AND MISC-
WALBRO 255 FUEL PUMP -
HONDATA S300 VER 1 ON A P28 ECU -
450 CC INJECTORS -
WORKING ICE COLD AC RETRO AC LINES TO MATCH INTEGRA AC COMPRESSOR -
FLUIDYNE RADIATOR -
FULL 3 INCH EXHAUST AND A APEXI WS2 MUFFLER - EBAY HIGH FLOW TEST PIPE -
MILD CHASSIS WIRE TUCKS -
BATTERY RE LOCATED IN FRONT OF PASSENGER FRONT WHEEL
PICTURES TAKEN 08/20/2016
THE UGLY
A TREE BRANCH FELL ON THE ORIGINAL TRUNK LID.
CLEAR COAT STARTING TO PEEL ON THE ROOF.
CAR IS LOUD DUE TO THE 3 INCH EXHAUST SYSTEM.
DONT HAVE POWER STEERING PUMP BUT THE LINE THERE FOR IT.
CAR DEFINITELY NEEDS A TUNE. I THREW A BASE MAP AND THAT IT. CAR RUNNING RICH.
ANY QUESTION JUST TEXT ME THANKS.
Pics: SCROLL DOWN
Year: 1998
Make: HONDA
Model: CIVIC
Mileage: 167,000
CHASSIS-
INTERIOR -
ENGINE -
ARP HEAD STUDS
DRIVETRAIN -
450 CC INJECTORS -
FLUIDYNE RADIATOR -
THE UGLY
