1998 Prelude h22 Auto to 5 Speed question!
Old Aug 19, 2016 | 10:27 PM
hondamyheart's Avatar
Default 1998 Prelude h22 Auto to 5 Speed question!
Hi,
My 94 Accord h22 / 5 speed was totalled last week. I have 98 Prelude Auto and i want to do manual swap. I will remove the transmission from my accord and install it on the prelude. I was just wondering which parts i need to replace on the prelude. Can i use (clutch slave cylinder, transmission bracket, clutch pedal and shifter linkage etc..) on the prelude?
Old Aug 22, 2016 | 11:37 AM
ESP.net's Avatar
Default Re: 1998 Prelude h22 Auto to 5 Speed question!
As you stated all mounts are the same. Just need to aluminum bracket that bolts of trans for prelude manual one. Rear T Bracket is the same as well.
Old Aug 22, 2016 | 08:49 PM
snobordboy's Avatar
Moderator
The pedal setup might be different, so you may need a Prelude 5th gen setup for that, but I believe everything else will swap over. Oh, and the shifter was different between 4th and 5th gen Preludes, so the Accord may be different as well.
Old Aug 23, 2016 | 11:33 PM
Thanks guys, Having hard time getting the shifter for 5th gen.
Old Aug 24, 2016 | 07:46 PM
92civlude's Avatar
You'll need to drill holes in the firewall for the clutch master cylinder. There isn't a plate as on other models.
Old Aug 29, 2016 | 04:17 AM
Removed old transmission, drilled hole from the MC, installed clutch pedal and brake. Wondering if the accord axles and half shaft would fit?
Old Nov 9, 2016 | 10:47 AM
thusee's Avatar
you'll also need to desolder a resistor on the auto ecu and move it over one slot.
Otherwise you'll get a check engine code. There is an article if you search on google, forgot what its called. There are pictures and descriptions of what you need in regards to parts and steps etc.
You can use the prelude auto axles, all you need is the midshaft off the manual engine.
THEROPE
Mar 3, 2014 05:36 AM
tpot90
Dec 12, 2008 06:31 PM
sony224422
Dec 13, 2007 08:05 AM
shox-h22a
Jun 19, 2005 08:41 PM
