1987 E30 325I Convertible
Old Aug 19, 2016 | 05:44 PM
EMinh1's Avatar
Default 1987 E30 325I Convertible
1987 BMW 325I
Bronzit / Mocha top
Millage: 155,000
Automatic 4 speed
Asking: 6,500 Obo
It is Originally from South Carolina, it carries no rust, all parts have been professionally installed throughout ownership at FMC: (Foreign Motor Cars of Quincy Ma) Most parts recent have less then 10k miles on them. Please feel free to contact me or reach out with questions.
Engine:
Head professional built per OEM SPEC by FMC 2016
KAmotors CAI w/ air duct
Scorpion bavauto dual-tip exhaust straight pipe
Suspension:
H&R cabriolet Race Spring
Billistien Race Shocks
Mason Engineering aluminum cross brace
All Rubber Bushing OEM (Tranny.Engine.Diff)
Suspension links replaced (tie rods in.out/control arms/endlinks/ swaybar bushing)
Setup:
Factory LSD
5mm front / 15mm rear H&R spacer w/ accommodated lugs
14x7 Basketweaves (Uniroyal 195/50/14)
Zimmerman Rotors all around
Posi Cool Pads
MISC:
BWA Stainless Steel Lines
Euro grill
Ellipsis head lights with Xenon HID
Black interior with Nardi trim (Interior is amazing condition)
Radio Delete
Suade Dash Cover
New Black OEM mats
New OEM Emblems
BMW Car Cover
BMW Sun Visor
///M pedals
The following work has been done
Maintenance Done: Waterpump/ Tensioner/ Belts/ Oil and BMW fluids done through FMC Steel Core Radiator has been pressurized and restored
Hood struts Trunk strut
Rear shocks and mounts
Front struts and mounts
Left and right motor mounts/Transmission and sway bar
Coolant flush Brake fluid flush Power steering flush transmission fluid rear differential Oil and filter
Front and rear Roundels All vacuum lines
soft top storage struts
Complete 100K service including plugs, wires, cap, rotor, coil, fuel filter, air filter, wipers
Rear muffler
New front and rear brakes ( pads, rotors and sensors)
Power steering return line and reservoir Oil filter housing relief valve oil and filter change
All cooling hosesThermostat and temp sensorPower steering lines
All Throttle body gaskets OEM floor mats
rear muffler hanger oil service and brake fluid flush
E-Brake handle and shift ****
New OEM Shadow Line Trim
Cons:
Top has wear and spots
Paint has some minor fade and chips
Top Tear:
Paint
Asking: 6,500 Obo may consider trades for Gsr / Swaped honda
Contact: MSG: (508)47l- 8l53 Max
91akira
Jun 18, 2019 08:29 PM
HondaGuy2020
Honda CR-V & Element
Oct 22, 2018 08:31 AM
thumper64
Apr 5, 2009 09:48 PM
chrisb
16
Feb 11, 2003 03:42 PM
